Kronos,
AFAIK there is only one out of the box Mac and MorphOS (2.8) compatible outthere (made by Sonnet and hard to find).
Is it the Tempo SATA Sonnet PCI ? http://www.sonnettech.com/support/kb/kb.php?cat=343#position_content
Cheap PC cards with the right chip should work (once you found a way to load boot.img from another device) and some of those might even be reflashed to work directly.
here a
Sil3512ectu128 PCI card (with two internal and two external ports) ; tell me more about "some of those might even be reflashed to work directly" , url/infos about ?
thanks, regards
