MorphOS 2.8 confirmed features
    Divinity
    Posts: 501 from 2009/9/8
    Oepabakkes,
    I also want to like to know more about SATA support. I understood well, MorhpOS on Powermac wouldn't even work with one of these cards installed ?
    probably the SCSI/SATA adapters here http://morphos.de/hardware.html will be usable in PowerMac G4 in MorphOS2.8 (atm these adapters are usable in Pegasos)
    I use atm a SATA card iSiI3x1x (but I have some problems) and a SCSI card Symbios 89x (sometimes also problems) in Pegasos2.
    Or can I already use such a card now with MacOSX on it ?
    In the PowerMac FW800 G4 I use atm a very good Adaptec card ; here as seen in pciscan in MorphOS2.7:
    Vendor 0x9005 <Adaptec> Device 0x10 <AHA-2940U2B SCSI Controller>
    This very good card is perfect in OSX Leopard 10.5.8 and OSX Tiger 10.4.x (not supported in MorphOS2.x)
    So it would be fine I can put Leopard on a SATA drive without touching the drives I use for MorphOS.
    In a PowerMac MDD and FW800 there is an ATA100 (also an ATA66 and ATA33), well I use a very good HD WD 500gb PATA and I have 60Mb/s throughput :) ;) ,so no useful to use (my opinion) a SATA bootstrap HD ; I also use the very good YABOOT for MorphOS2.x, Leopard OSX, Tiger OSX, Panther OSX and Linux Debian ... all in these OS in one HD 500gb :)
    here a guide about YABOOT if interested http://www.nonsoloamiga.com/forum/viewtopic.php?f=25&t=106
    In a PowerMac AGP graphics, gigabit ethernet, quicksilver 2001/2002 It could be useful to use an HD SATA via SATA adapter (ATA inside is only ATA66), this is my opinion.
    Sonnet has/had good SATA controller for PowerMac, Tempo SATA controller models ( look at here for exemple http://www.sonnettech.com/support/kb/kb.php?cat=284#position_content ) usable in OSX
    [ Edited by Divinity 08.08.2011 - 22:13 ]
  • »08.08.11 - 18:32
    Divinity
    Jim,
    Will MOS2.8 be able to boot from SCSI or SATA controllers or will these drive only work after booting from PATA?
    not useful SCSI HD bootable ... but yes you can bootstrap from HD SCSI and SATA, but the kernel need to be in a "bootable"/viewable unit for the OpenFirmware (in Macintosh) and for SmartFirmware (in PegasosI/II and Efika)
    For exemple you can have an hd PATA in a Mac (with inside the MorphOS kernel boot.img, bootinfo.txt) and a bootable SFS partition in a HD SCSI or SATA (if SCSI and SATA host adapters supported in MorphOS2.x)
    [ Edited by Divinity 08.08.2011 - 21:41 ]
  • »08.08.11 - 18:39
    Posts: 2560 from 2003/2/24
    Just a sidenote:
    Macs CAN boot from PCI-devices (if these have an OF-BIOS onboard). My 2x1.8 QS came with an 400GB IDE HD connected too an ATA133+2SATA PCI card and it booted OSX just damn fine.
    [ Edited by Kronos 09.08.2011 - 00:22 ]
  • »08.08.11 - 20:20
    Thanks Kronos. That's an interesting option.
    What controller are you using?
  • »08.08.11 - 21:34
    The onboard one as the combo-card is not supported by MorphOS (and probraly will never be).
    O.k. I could have put the boot.img and maybe an ISO-file of the MorphOS-CD to claim some level of booting from SATA ...
    AFAIK there is only one out of the box Mac and MorphOS (2.8) compatible outthere (made by Sonnet and hard to find).
    Cheap PC cards with the right chip should work (once you found a way to load boot.img from another device) and some of those might even be reflashed to work directly.
    Just wait for 2.8 and see what the otions are...
  • »08.08.11 - 22:08
    analogkid
    Posts: 715 from 2004/11/3
    To be precise, it's this one:
    http://www.sonnettech.com/product/tempo_serial_ata.html
    It's a two-port card with a Sil3112 controller...
    Mine is waiting for its use in my Powermac G4...
  • »09.08.11 - 03:07
    dIGIMAN
    Posts: 273 from 2005/11/7
    Why that complicated?
    I never booted from hd with my powermac from the beginning.
    I am using a dedicated usb key with the boot.img on it. The leaves
    open which i boot next, if supported or not :)
  • »09.08.11 - 04:06
    Simon
    Posts: 809 from 2008/7/6
    What hard to find card ? Sonnet still sells it and I found 4 on Ebay ... but they between 80 Dollar and 80 Euro without shipping. Well if it that is what it takes to run Leopard without touching the MorphOS hd's on the internal port and I guess it keeps a certain value.
  • »09.08.11 - 05:48
    analogkid
    @Oepabakkes
    Well, "hard to find" is often connected to the price you are able or willing to pay... I think in this case Kronos meant a SATA card for a reasonable price, or as a complete Powermac G4 package (e.g. with CPU-card, advanced Radeon card etc.).
  • »09.08.11 - 06:10
    Simon
    Understandable, but when was Amiga computing ever cheap if you talk about new hardware ? Even old vintage hardware is sometimes worth VERY good money.
    About this card: Sonnet is quality and the price at Sonnet's shop is reasonable for people in the USA -I think- and in Euro's +/- 57 Euro. But at the German Ebay it's horrible 80 euro + shipping 20 euro. Ouch.
  • »09.08.11 - 13:11
    Posts: 1353 from 2004/2/8
    when was Amiga computing ever cheap if you talk about new hardware?
    Like... in1985? When you could get a A1000 with monitor for 1595$ while Apple Macintosh costed 2,5 grand, and the IBM PC Junior (64 KB of RAM, one 5,25 floppy and no monitor) costed 1300$ ?
  • »09.08.11 - 13:38
    Simon
    1595$ wasn't exactly cheap 26 years ago. A C64, that was cheap in 1985.
  • »09.08.11 - 14:26
    stephen_robinson
    Posts: 746 from 2007/4/22
    Will there be a native MorphOS Professional File System for 2.8?
  • »10.08.11 - 19:41
    pampers
    Posts: 1067 from 2009/2/26
    Considering this two posts, I think meaby..
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7805&post_id=83059&viewmode=flat&sortorder=0&showonepost=1
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7805&post_id=83090&viewmode=flat&sortorder=0&showonepost=1
    Omg, am I Andreas now? ;)
    [ Edited by pampers 10.08.2011 - 22:57 ]
    MorphOS 3.x
  • »10.08.11 - 19:56
    Posts: 12529 from 2003/5/22
    Don't worry, you're just using the Web in the way it was meant to be used. There's nothing bad about that, as opposed to what some people might tell you ;-)
    (You should change the sortorder to "1" in your second link as an ugly workaround for the MZ bugs.)
  • »10.08.11 - 20:15
    analogkid
    @pampers
    "Omg, am I Andreas now? ;)"
    No, because you aren't quoting your own posts.
  • »11.08.11 - 03:36
    And more importanly he is not doing it 3 levels deep......
  • »11.08.11 - 05:27
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    Andreas_Wolf,
    The way you post links to a post that contains links, whcih then contains links to the releavant post is not in any way shape or form a good way of using forums. If you have found the info just bloody post it.
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »11.08.11 - 07:20
    Posts: 2730 from 2003/2/24
    +1
  • »11.08.11 - 07:58
    Do you know a better way to provide updates, addendums and corrections to posts you made before? Most often, merely editing the posts wouldn't cut it in my opinion.
  • »11.08.11 - 09:13
    Thanks for sharing your opinion on me but obviously I wasn't referring to myself but to pampers and his exciting discovery of the possibility to use hyperlinks on the Web, which it seems he thought was something only I can do. He's apparently still a rookie though as his second link doesn't work ;-)
  • »11.08.11 - 09:22
    How would that even work, quoting something "3 levels deep"? In case you mean something like the following:
    >>> my own gibberish
    >> my own gibberish
    > my own gibberish
    my own gibberish
    ...where did I do this? I can only remember quoting myself as much as 2 levels deep ;-)
  • »11.08.11 - 09:35
    Simon
    Should we make a useless Amigaworld.net-style poll with Andreas as the subject ?
  • »11.08.11 - 11:17
    Mabo
    Posts: 67 from 2010/5/3
    Hi there! What about wifi in the new release ?
    Bye bye  :-)
  • »11.08.11 - 14:20
    pampers
    I'd say we will find out when new release will be available :)
    MorphOS 3.x
  • »11.08.11 - 14:58
