ARM for the future?
    Posts: 2053 from 2003/6/4
    Jim,
    While I find Zylesea's argument for a low end PPC system somewhat unappealing,
    That's all a matter of price. I also think a cpu of the e300/400 class is not first choice for general computing today (but am typing this particular post using my e300/400 computer), but as a little toy/fun thing/low performance - low wattage thing for pocket money it actually may make some very good sense.
    Look to this raspberrypi guy - he got quite some attention for a probably similar powerful device.
  • »28.05.11 - 23:00
    Posts: 12058 from 2003/5/22
    Just in case his name doesn't ring a bell to anyone: http://hol.abime.net/hol_search.php?N_ref_artist=256 :-)
  • »28.05.11 - 23:16
    Sorry Zylesea. I can understand your point, but for a few dollars more we can have a much more powerful system.
  • »29.05.11 - 03:10
    Sure, for a few more bucks you can make more powerful systems, but then the competition snaps in. For a more powerful system you'll soon reach price regions where Atom et al are home already. Indeed it is possible to sell stuff there, too. But the whole key is that with the 512x family you could offer small cheap computers which in that kind are pretty rare yet. Nothing to do too seroius computing on, but for fun, for niche, for lowest price. That's the whole point.
  • »29.05.11 - 14:42
    Yes, and I'd agree you have a very valid point. By the time you factor in a Cortex A9 you're probably at Atom price levels. The fact that there is a processor that can under cut Atom prices makes it worth considering.
  • »29.05.11 - 17:00
    >> If it wasn't a little buggy, I would already be using a Pandaboard.
    > There are also other Cortex-A9 boards, for instance the Snowball
    > (available end of Q2/2011 starting at 225 USD)
    And another one (Origen) starting at 199 USD (available end of June):
    http://www.origenboard.org
    http://www.youtube.com/watch?v=d1rlCTNOiyA
  • »30.05.11 - 12:11
    minator
    Posts: 365 from 2003/3/28
    You beat me to it!
    Probably the fastest ARM around right now CPU and GPU wise (The GPU is a quad core Mali-400).
    It's the same chip as the Galaxy SII, more powerful than the iPad2!
  • »30.05.11 - 13:02
    Yes, it's 20% higher clocked than the SoC on the Snowball board, which seems to have only single-core Mali-400.
  • »30.05.11 - 13:42
    >> Probably Consoles as well.
    > "01net also claims to know some of the technical specifications of the new console
    > (translation from Develop): 'CPU is custom IBM PowerPC with three cores [...]'"
    > http://en.wikipedia.org/wiki/Project_Caf%C3%A9#April_2011
    More rumours, this time regarding another console:
    "IBM sources claim that the new multi core PowerPC processor, which Big Blue, has spent several years developing is now part of a joint development project with the Japanese company. [...] The new 32nm Cell processor is tipped to be capable of up to 16 SPEs which is twice as fast as the current Cell processor according to IBM leaks."
    http://www.smarthouse.com.au/Gaming/Industry/F5C6F8A6
    (I remain very sceptical regarding this specific article as it contains some severe factual flaws.)
  • »31.05.11 - 11:03
    minator
    I've heard the 3 core IBM Wii2 a few times now. Sounds perfectly plausible.
    Sony recently said they're not spending as much on the PS4 development so if anything that points to a new version of Cell. Anything else means they'll have to rewrite everything and that'll be rather expensive.
    Adding a second Cell, upping the RAM and updating the GPU is the easiest option technology wise and gives them backwards compatibility. At 32nm they can probably up the clock quite a bit as well. IBM already had better Cell tech in the works so it could be a better version of Cell. IBM didn't stop Cell development (they publicly canned one chip and everyone thought Cell was dead). They had been working on a 32SPE + 4 PPE chip with the PPEs based on a POWER7 core. Don't know what happened to it but they said they were merging Cell with something else, presumably POWER.
  • »31.05.11 - 22:11
    As I read the article linked to above the PS4 is rumoured to be powered by a single (new) Cell processor with 16 SPEs. Maybe this new Cell will have two PPEs (like the cancelled PowerXCell 32ii was supposed to have, only with half the amount of SPEs) but I doubt they will put two Cell chips there as I think it wouldn't make sense if they're going to have a new Cell chip developed anyway.
    Indeed.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=6768&start=35
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=6993&start=80
    Actually, it was two chips.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=6993&start=70
    Yes, which was surprising as the declaration of death was qualified almost immediately:
    http://www.hardwareheaven.com/news.php?newsid=344
    ...and one with 2 PPEs.
    Interesting, I hadn't read that anywhere before. I'd rather have suspected a POWER6 offshoot. No IBM roadmap document on PowerXCell 32ii and 32iv I ever came across mentioned the base of their enhanced PPE called PPE' therein. A quick googling revealed this as the source for the POWER7 claim (translated):
    http://translate.google.com/translate?sl=ja&tl=en&u=http%3A%2F%2Fd.hatena.ne.jp%2Fpetacell%2F20080621
    Thanks for this bit of info.
    Yes, that's what I understood as well (see first two links).
  • »31.05.11 - 23:27
    SPEs servicing a much more powerful out of order Power processor core?
    Sounds great. Should be much more powerful then any proposed Cell derivative.
    The only negative to this is the attendant increased complication creating optimized code for any CPU coupled with SPEs.
  • »01.06.11 - 01:35
    That depends on the definition of "Cell derivative". I suspect most people would have called 32 SPEs servicing two or four trimmed POWER7 cores, all packed together in a chip named PowerXCell 32ii or PowerXCell 32iv, a "Cell derivative". I'd say the inclusion of the SPEs is what makes a Cell a Cell. Thus any number of SPEs servicing one or more trimmed POWER8 cores, all packed together in one chip, would be called a "Cell derivative" by most people as well, I guess. That said, it's interesting to think about whether non-trimmed POWER8 + SPEs would be percieved as POWER with added SPEs or rather as Cell with POWER PPE ;-)
    At least compared to current Cell chips there would be no such increase. And regarding the PPE an out-of-order core requires less optimization than an in-order core ;-)
  • »01.06.11 - 02:03
    THAT'S an interesting definition Andreas.
    From my examination of the two Cell processor that were made and the immediate potential successors, I thought the shift to a Power 6 successor (as the core CPU) was really significant.
    Of course, the SPEs have also evolved. CellBE's SPE were much less powerful then its sucessor's SPEs.
    So both the Core CPU (PPE) and its attendant SPEs continue to evolve.
    Power7's core processor should be far beyond any previous PPE core. As we don't yet know how much improvement has been made in the SPE's perhaps my biased focus is unjustified.
    Is it a Cell derivative? Yes, I guess it is. But as a Power6 successor Its also so much more.
  • »01.06.11 - 02:37
    Yes, that's a given, even if stripped down. The same applies to POWER8 to an even greater extent. If the PS4's Cell should have a POWER PPE I'm inclined to believe it will be derived from POWER8, not from POWER7 like was planned for the PowerXCell 32ii and 32iv.
    True. According to IBM roadmaps the PowerXCell 32ii's and 32iv's eSPE was not supposed to improve in SP FP or DP FP performance over the PowerXCell 8i's eDP SPE. Some suspected cache enlargement and latency reduction though.
    http://www.google.com/search?q=powerxcell+edp+espe
    So we have the same point of view. Nice.
    That's called product line evolution ;-)
  • »01.06.11 - 04:49
    Product evolution I first heard mention of here, thanks to your tireless investigations.
    At the time you first mentioned this, I thought no ******* way.
    I've got to stop being surprised when you correctly intuit something. You don't speculate or predicate. You make some very accurate analysis.
    I wonder how this will affect Power's use in consumer oriented products.
    Do you think we might see a return to the desktop or use in devices like the PS4?
  • »02.06.11 - 01:57
    Probably not that much, assuming you mean IBM POWER here. Non-trimmed POWER will never be in any consumer product, no matter if with or without SPEs. The rumour article I quoted says that Sony wants to use the PS4's Cell also in notebooks and in TVs. So if this new Cell is going to have a trimmed POWER core and will be in notebooks and TVs then that would mean (some) usage in consumer oriented products. But as you might have noticed, these are no less then three ifs: 1. Will the PS4 really use a Cell? 2. If it'll use a Cell, will its PPE really be derived from POWER? 3. If it's a Cell with a POWER(-derived) PPE, will it really be used in notebooks and TVs?
    No, not in a scale that would generally be understood as a return (to what we had with the POWER4-derived PPC970).
    Yes, I think a new Cell in the PS4 might have a trimmed POWER PPE. But that's really just speculation.
  • »02.06.11 - 02:51
    Sony has made statements that might be interpreted as indicating that the design would be more evolutionary (rather then revolutionary). As such a Cell seems likely. But a Power derived Cell is a complete unknown. Therefore, whatever else they use it in could but may not be Power related.
    But Sony's potential use in computing devices would be, at least, a small return.
    I'm beginning to get that impression as well. Considering the timel ine mentioned for introduction, the next Cell processor used in the PS4 could easily benefit from IBM's developments.
  • »02.06.11 - 03:27
    True, assuming you refer to real products and assuming you mean POWER here, not Power ISA in general. As we established before in this thread, both the PowerXCell 32ii and PowerXCell 32iv were suspected to come with PPEs derived from POWER7.
    Only if such new Cell with POWER-derived PPE is going to act as the CPU of (at least some of) Sony's future notebooks. As you may remember, when Toshiba was said to have Cell technology in their notebooks all they eventually released were some models in their Qosmio line with the SpursEngine (i.e. only SPEs, no PPE) acting as a video coprocessor chip for the x86 CPU. We'd have to see if Sony's ambitions in that regard would be more serious or if they would replicate Toshiba's way regarding notebooks containing technology based on a new Cell.
    That's a given, no matter if the new Cell's PPE will be derived from IBM POWER or be any other Power Architecture compliant core developed by IBM. One of those two options would be realized for a new Cell for sure.
  • »02.06.11 - 12:22
    minator
    Just to be different, I'll say something on-topic (-:
    It was computex this week and a load of ARMs were launched, confirmed or shown off.
    TI announced a new OMAP with dual core 1.8GHz Cortex-A9s
    Nvidia were showing off their Kal-el quad core A9 chip.
    Qualcomm are sampling their new chip soon, it's another dual core but it goes up to 2.5 GHz. It's also a new microarchitecture - There's very little details but given their claims it sounds like it'll be something similar to the Cortex-A15.
    Currently the A9 is in PPC G4 territory performance wise.
    The 1.8GHz A9s should put them up against the G5s and it looks like ARM beating all the G5s could be maybe only a year away.
    Then there's Nvidia's project Denver at the end of next year which sounds like it'll be more in the range of current desktops.
    It's gonna get very interesting in the next year or so...
  • »03.06.11 - 23:43
    Nice. Three days before that announcement I had just been talking about Krait having been announced for sampling for Q2/2011 right here in this thread.
    At least regarding Dhrystone performance it's estimated to be a bit below (estimated) Cortex-A15 performance.
    G4 exists between 350 MHz and 1.7 GHz (2.0 GHz overclocked), which means a factor of about 5 to 6 from slowest to fastest, so I think you should specify your statement a bit more. So which clock rate in G4 do you think a 1.2 GHz (which I think is the current max) Cortex-A9 roughly resembles performance-wise? After all, beating a 350 MHz G4 would be a no-brainer even for Cortex-A8 ;-)
    That's a bold theory. I think it should be hard for a 1.8 GHz Cortex-A9 to beat even a 1.6 GHz G5 (the slowest of the bunch) let alone a faster one performance-wise.
    Beating a 2.5 or even 2.7 GHz G5 with a 2.0 GHz Cortex-A9 is definately not possible. First Cortex-A15 based chips are minimum 1.5 years away.
  • »04.06.11 - 01:50
    So we've got a couple of years before ARM reaches the processing power of CPUs we are currently targeting?
    A 1.8 Ghz A9 still sounds interesting. With built in GPUs, these SoCs are usually pretty low cost.
  • »04.06.11 - 02:08
    Not about a new Cell, but this started circulating 5 days ago:
    http://img12.imageshack.us/img12/1228/prcspec13iu.jpg
  • »04.06.11 - 16:27
    Andreas_Wolf,
    Multi-core Power6? Wow! How accurate do you think that document is?
    Could it really be a Nintendo internal document or just an elaborate fake?
  • »04.06.11 - 16:46
    > Multi-core Power6?
    I think that would be more like "POWER6-derived", in a "trimmed down" (except for the number of cores as POWER6 is dual-core only) sense.
    > How accurate do you think that document is? Could it really
    I really don't know. This spec sheet has been heavily discussed since it emerged and it's far from being undisputed. We'll know for sure in a few days I guess.
  • »04.06.11 - 16:54
