eBay - for sale - sonnet encore 1.8ghz cpu with all goodies
    No, MorphOS2.7 does not use both CPU's on a dual G4 PowerMac. There has been some talk between the developers regarding a slight possibility that they could perhaps some day in the distant future do some kind of AMP to some how take advantage of the second CPU, but it might never happen. The Team and other developers say that SMP would break all compatibility with existing Amiga and native MorphOS2.x apps and games.
  • »24.12.10 - 05:52
    Simon
    Posts: 809 from 2008/7/6
    As for now it does not use that second cpu, and I don't think it's planned in the near future ... if at all. If you want to use dualboot with another operating system ... you probably could benefit from dualcpu.
    If you go for an older Powermac, get a Digital Audio (Powermac 3.4) if you can. Quiksilver (Powermac 3.5) has some problems with 1.5Gb ram, while the Digital Audio does not. If you want MDD ... get one with a 167Mhz bus.
    [ Edited by Oepabakkes on 2010/12/24 9:13 ]
  • »24.12.10 - 05:52
    CountRaven
    Posts: 566 from 2007/12/10
    Which is the faster Digital Audio Model existing in dual -if any- and single pcpu?
    If I put 1Ghb or 2Gb RAM on a QuickSilver will I have to face those probs?
  • »24.12.10 - 05:59
    Simon
    they are as fast as the cpu you place in it. if you stay to OEM cpuboard, an overclocked dual 1Ghz running at 1.2Ghz is as fast as you can get with it... if you want to go faster, you will have to get Sonnet or as such.
    1Gb is more or less the maximum for a Quicksilver running MorphOS. 2gb is only possible with MDDs
    [ Edited by Oepabakkes on 2010/12/24 9:19 ]
  • »24.12.10 - 06:19
    CountRaven
    hmmm are there MDD running at 2Ghz without any upgrades? Is the OEM version or somekind of overclocking method is hidden behind?
    ps. thanks for the answers and sorry for the lot of questions but it is now that I take the big trip with PowerMacs g4 and I am a bit confused and lost with all those models.
  • »24.12.10 - 06:27
    Posts: 12539 from 2003/5/22
    > are there Quicksilver 2002 models that run on 1.25Ghz?
    At least not without overclocking or 3rd party CPU upgrade.
  • »24.12.10 - 06:33
    Simon
    1.42ghz is the fastest Apple did in the powermacs. Everything faster is overlocked or third party.
  • »24.12.10 - 06:44
    http://support.apple.com/kb/SP113
    That's without 3rd party CPU upgrade of course.
  • »24.12.10 - 06:44
    ...and PowerMac3,1 to 3,3. But MorphOS can only see max 1.5 GiB RAM anyway.
  • »24.12.10 - 06:51
    CountRaven
    1.42Ghz... I see
    Is it single od dual? and which model is it?
  • »24.12.10 - 07:28
    Simon
    Powermac MDD 1.42Ghz, only in dual version.
  • »24.12.10 - 07:43
    Simon
    Anyway , you might want to check this wiki:
    http://en.wikipedia.org/wiki/Power_Mac_G4
  • »24.12.10 - 07:43
    Considering the processor we are both using, I'd like to see a comparison to an MDD 1.42. Its got a 167Mhz bus, but the memory benchmarks aren't that much higher than the Sonnett card . The 7455 also has L3 cahe the 7447 lacks, but there is an almost 400Mhz advantage to the Sonnett.
    Personally, I think it would be close.
  • »25.12.10 - 02:25
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7372&forum=11&post_id=76637#76637
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7419&forum=11&post_id=77395#77395
  • »25.12.10 - 08:18
    Thanks Andreas. That confirms what I thought (that I don't have to worry about any smack talking 1.42 MDD owners).
    But how much better would the 7448 based accelerators be?
    Has anyone tested that?
  • »27.12.10 - 00:11
    Let's have a closer look at the relevant Barefeats' tests I indirectly linked to in my previous posting:
    http://www.barefeats.com/g4up.html :
    The 7455 at 1.42 GHz is faster than the 7447A at 1.8 GHz in 5 out of 8 tests, namely in one of the two Photoshop tests and in all four 3D game tests.
    http://www.barefeats.com/g4up2.html :
    The 7455 at 1.42 GHz is faster than the 7448 at 1.8 GHz in 2 out of 6 tests*, namely in the two Photoshop tests.
    Comparison (clock per clock) of 7447A vs. 7448 from http://www.barefeats.com/g4up2.html :
    iMovie: 7448 is 3.0% faster.
    Cinebench: 7448 is 4.4% faster.
    Doom 3: 7448 is 12.5% faster.*
    Halo: 7448 is 10.8% faster.
    Photoshop CS: 7448 is 6.6% faster.
    Photoshop CS3: 7448 is 5.9% faster.
    In dnetc however there's no significant advantage to the 7448 over the 7447A/B:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7001&forum=3&post_id=80363#80363
    * Seeing that in Doom 3 benchmark the 7448 at 1.8 GHz is 12.9% faster than the 7455 at 1.42 GHz we can assume that in Doom 3 the 7447A at 1.8 GHz and the 7455 at 1.42 GHz would be about on par (7455 being 1.2% faster).
  • »27.12.10 - 12:27
    So, from those test results, it would appear that for many every day actual tasks the 1.42GHz MDD is actually faster than the 1.8GHz 7447A Sonnet accelerated Quicksilver, or Digital Audio PowerMacs.
    I don't know what everyone has been paying for their Sonnet upgrade accelerators, but the prices I have seen have been higher than the prices I have seen for complete 1.42GHz MDD PowerMacs, so at least where I live, the better "bang for the buck" would be to buy a 1.42GHz MDD PowerMac.
    For bragging rights, having a 1.8GHz PowerMac sounds better than any actual speed advantage, over having a 1.42GHz PowerMac, unless the 1.8GHz accelerator happens to have a 7448 G4, instead of a 7447A G4 CPU. (are 7448 G4 accelerators available for any model of G4 PowerMac? Which manufacturers use the 7448 G4 @ 1.8GHz in their accelerator cards? Which G4 cpu model is available @ 2.0GHz and is it compatible with MorphOS2.x?)
    For me, I think it would be better to stick with what I have, unless I can swap my dual 1.25GHz G4 cpu module (in my non-FW800 MDD) with a dual 1.42GHz G4 cpu module without losing my ability to run MacOS9.2.2, which I need to run the version of Media Composer that works with my Avid Meridien PCI cards and break-out boxes.
    A dual 1.42GHz G4 module over-clocked to 1.5GHz, or maybe 1.67GHz to match the buss speed, would likely be the fastest G4 PowerMac for me. But I don't know how, or if it is even possible to use the later dual 1.42GHz G4 cpu modules on the earlier, non-FW800, dual 1.25GHz G4 motherboards, even though they look the same physically.
    Thanks for the www.barefeats.com comparisons Andreas.
    [ Edited by amigadave on 2010/12/27 9:01 ]
  • »27.12.10 - 14:59
    5 out of 8 tests? No, that's not a clear lead at all. Its about parity. And I was really hoping the 7448s wouls produce more of an advantage (maybe the lower memory bandwidth affects this).
    I will agree that an1.42Ghz Mdd is a more sensible buy though. You've got better disk controllers (isn't there an additional ATA controller - both ATA 100 instead of ATA66). and DDR apparently allow some increase in non cpu i/o tasks.
    But overall, I don't see any really big jumps from using an MDD. It's nice to know that older Powermacs can be easdily upgraded to performance levels near the best Powermac produced.
    And while Sonnett upgrades are going up in price (and the 7448 upgrades are outrageous), I got mine gor $150. Although that is astupid compared to to the 69.95 I recently spent on a Phenom X3. that runs at 3.3 Ghz.
    Can anyone tell me about the PCI slots in the Powermac? They're long than standard PCI slots and look like PCI-X slots.
    [ Edited by Jim on 2010/12/27 17:57 ]
  • »27.12.10 - 15:56
    Yes, that's how Barefeats did their tests. Further example from this very site:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=7474&start=28
    Newer Technology and PowerLogix. Besides, Daystar had a prototype.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=6770&start=26
    7447A/B/C (Newer Technology and PowerLogix, apparently also Giga Designs) and 7448 (Newer Technology), all overclocked by the respective card manufacturer, of course.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=6993&start=25
    Yes, both are (7448 starting with MorphOS 2.7):
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7592&start=10
    A multiplier of 9 (1.5 GHz) isn't any worse than one of 8.5 (1.42 GHz) or 10 (1.67 GHz). It's all matching the bus speed.
    > [...] I don't know how, or if it is even possible to use the later dual 1.42GHz G4 cpu
    That should be possible. And the ability to run OS9 is bound to the mainboard AFAIK, so you wouldn't lose it.
  • »27.12.10 - 16:05
    Yes, as well as lack of L3 cache.
    These are 64-bit PCI slots. Compare:
    http://upload.wikimedia.org/wikipedia/commons/6/6f/PCI_Keying.png
  • »27.12.10 - 17:26
    Great reference Andreas. I assume we're still talking about 33Mhz slots (as opposed to PCI-X's 66Mhz).
    Btw - I have received more useful information from you in the last year than from some people I've known my entire life. Thanks.
  • »27.12.10 - 17:38
    Correct. PowerMac G4's PCI slots have a 64-bit width at 33 MHz clock. There's a nice table on German Wikipedia:
    http://de.wikipedia.org/wiki/Peripheral_Component_Interconnect#Allgemeine_PCI-Bus-Spezifikationen
    So it's either PCI 64-bit v2.1 or PCI v2.2 in the PowerMac G4.
    Actually, there is PCI at 64-bit width and 66 MHz clock specified since 1994 (see table referenced above). As far as I understand, PCI-X at 66 MHz *is* 64-bit PCI at 66 MHz. "Real" PCI-X (as in "better than best PCI") only starts at 133 MHz.
  • »27.12.10 - 18:16
    So the expansion slots on a G5 run at 133Mhz? Wow.
  • »27.12.10 - 18:22
    According to http://en.wikipedia.org/wiki/PowerMac_G5#Product_revision_history and http://www.everymac.com/systems/apple/powermac_g5/faq/powermac-g5-number-type-speed-pci-pci-x-pcie-slots.html the PowerMac G5 has mixed PCI-X slots: some 100 MHz and some 133 MHz. So it seems "real" PCI-X starts at 100 MHz, not at 133 like I told before.
    Btw, the last PowerMac G5 generation's PCIe runs at 2500 MHz ;-)
  • »27.12.10 - 18:29
    The future for MorphOS hardware looks very promising!
  • »27.12.10 - 19:05
