New SAM460EX
    KimmoK
    Posts: 102 from 2003/5/19
    >> I think they should forget the x3500
    >In fact, I see indications that this may be the case.
    IMO, P5010 might be more usefull than P3041 option.
    (and someone else should do T1 based boards for low end, then all new boards would use the same generation of CPU cores.)
    :-x :-P 8-)
  • »18.07.14 - 15:31
    I have been saying that for awhile.
  • »18.07.14 - 17:03
    Yasu
    Posts: 1724 from 2012/3/22
    What would the difference between the X3500 and the X5000 be anyway?
    My MorphOS blog
  • »19.07.14 - 21:42
    It uses a processor with a different core.
  • »19.07.14 - 22:20
    Posts: 12079 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7001&start=799
    Jim is right. Details there:
    http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=P5040
    http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=P5020
    http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=P3041
  • »20.07.14 - 00:50
    Personally, I don't find the e500mc core particularly attractive when low cost e5500 based products are available.
    Then there are the new PPC476FP based products Andreas has mentioned.
    And AMCC almost had a few decent introductions (although they appear to be moving off into ARM).
    Frankly, I would like to see A-eon drop the X3500 and introduce an X6500 with an e6500 cored cpu.
    [ Edited by Jim 20.07.2014 - 05:14 ]
  • »20.07.14 - 01:42
    > I would like to see A-eon [...] introduce an X6500 with an e6500 cored cpu.
    I believe that may be the plan anyway, as successor to the X5000 (and probably with a different name).
  • »20.07.14 - 09:36
  • vox
    vox
    Posts: 524 from 2003/11/25
    Well, thread has gone to AEON Cyrus boards, but please do update it with any SAM460 and MorphOS news, when related.
    On the AEON topic (maybe should be separated) as far as I do remember Trevor stated in Obligment interview "- Are the ports of Linux, AROS and MorphOS are possible on the AmigaOne X1000 ? Will you encourage this ?
    While I personally have no objection to other Operating Systems being ported to the A1-X1000 our main aim is to provide a modern power platform to showcase the advanced features of AmigaOS. The A1-X1000 has been developed specifically to run AmigaOS 4 and will be supplied with AmigaOS 4 from the beginning. However, we certainly won't discourage people who want to port other Operating Systems to the new hardware."
    Which generally means that IF MorphOS team decides (Before going ARM, x64 or whatever) that e.g. Cyrus is viable and avail platform, faster and modern then G4 and G5 Macs (where AmigaOne X1000 failed mainly because of CPU choice) in despite of price, they can support it too.
    From discussion, solely as new and modern PPC board Cyrus does generate interest. And what would be most interesting to see is MorphOS fully supporting such boards before AmigaOS 4.x :-) At the other hand, like with SAM460ex, some audio and gfx drivers development to PCI-E cards would be overall benefitial for development of OS.
    As usual, just theoretical talk. But its good to see Trevor publishes MorphOS related news on his blog too and updates it regularly.
    Lame PC with AmiKit XE
  • »09.08.14 - 14:52
    number6
    Posts: 480 from 2008/8/10
    @vox
    Your quote is from 2010.
    A lot has happened since then.
    #6
  • »09.08.14 - 16:39
    This will happen more likely in that thread: https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8931&forum=11
    > IF MorphOS team decides [...] that e.g. Cyrus is viable and avail platform,
    Absolutely. And I'm not even sure it really must be "faster [...] then G4 and G5 Macs", as can be seen by the announced Sam460 port.
    Which on-board component(s) do you have in mind here?
  • »10.08.14 - 05:29
    > Your quote is from 2010. A lot has happened since then.
    Is there anything in Trevor's quote that you think isn't valid today anymore?
  • »10.08.14 - 05:33
  • vox
    vox
    OK, thanks. I see SAM440 is also mentioned, which would be nice. As CPU its quite the similar chip, surely a board is a bit different.
    >Absolutely. And I'm not even sure it really must be "faster [...] then G4 and G5 >Macs", as can be seen by the announced Sam460 port.
    Simply by tech sheet honestly those Freescales looks so nice they should be new enough to be faster, that I kind of bite myself for not waiting longer and buying X1000 in announced last batch. But I do agree as with Efika, its not the high end that is goal, but versatility of platforms. Its good to have
    On a lot has changed since 2010 sidenote, I haven`t seen Trevor being against MorphOS or new blue vs red war recently. In other words I don`t see what has changed to worse.
    In the end, those systems (Acube,AEON) will go on sale madatory with OS4, but no one can stop another operating system from supporting them. More honest question would be will Trevor offer free system to developers - which I believe he did with X1000 but platform itself wasn`t attractive as slower then Macs.
    >Which on-board component(s) do you have in mind here?[>/quote]
    SAM460 - full onboard SATA2, RadeonHD with 3D
    x1000/Cyrus - onboard Network, mem card onboard, RadeonHD with 3D, even any use of second core and beyond
    Its a bit sad that after years so far sam440 is basically only fully supported board from hardware side (by OS4). Driver thing kills rest of good feelin and MOS does better job there.
    + Filesystem support that would enable file share between AmigaOS, Linux and MorphOS
    + More WiFi cards supported with some nice info on avail, connected, speed
  • »11.08.14 - 13:55
    number6
    Publically we know that linux distros have expanded for Amigaone X1000 since Trevor's interview from 2010.
    In fact the link from XENO, who is a big part of these projects is fairly prominent - "amigalinux.org".
    Source
    I would suggest discussing anything beyond that would be better served by contacting Trevor directly.
    #6
  • »11.08.14 - 14:27
    As platform not to be supported, yes.
    Yes, depends on the definition of "similar":
    http://amigaworld.net/modules/news/article.php?storyid=5807&start=60#77871
    I'm not sure a 2.2 GHz e5500 is faster than a 2.7 GHz PPC970 core.
    The port to the Efika 5200B was paid for, that's the reason it exists.
    The port to the Sam460 has been primarily worked on to have a target platform that's available as new.
    > I haven`t seen Trevor being against MorphOS [...] recently.
    I haven`t seen Trevor being against MorphOS ever ;-)
    Also for ACube's industrial customers? ;-)
    "They never sent me an X1000 as promised so I could support the mainline kernel on it, so I'm sorry but you're mostly on your own here."
    https://bugzilla.kernel.org/show_bug.cgi?id=67811#c1
    Okay.
    > RadeonHD with 3D
    Not an on-board component.
    Yes, on-board network driver for X1000 has been available only for betatesters for over a year.
    > mem card onboard
    Okay.
    > RadeonHD with 3D
    Again, not an on-board component.
    Not likely, I think.
    FAT? NTFS?
  • »11.08.14 - 21:14
  • vox
    vox
    Basically as CPU is almost the same changed frequency and cache.
    https://en.wikipedia.org/wiki/PowerPC_400#PowerPC_460
    I ment in multicore edition. As far as I can see it has slightly more DMIPS/Mhz to compensate the difference, slightly more cache and a bit better FPU which slould bring about the asme user feeling. We ll know more once we have the Cyrus and Linux to test it.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7001&post_id=74512&viewmode=flat&sortorder=0&showonepost=1
    >The port to the Sam460 has been primarily worked on to have a target platform that's >available as new.
    Which I interpret as versalility - availiability of both high performance and low performance, used and new hardware (even in this case used hardware outperforms new)
    To be honest, never heard of, even that would be nice for them (to sell it as Linux embed sys and to have more sales)
    >"They never sent me an X1000 as promised so I could support the mainline kernel >on it, so I'm sorry but you're mostly on your own here."
    That is about Linux?
    I believe they were offered the Nemo board (and that Trevor would honor that still if asked politely)
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7183&post_id=74161&viewmode=flat&sortorder=0&showonepost=1
    >Okay.
    Which OS4 doesn`t support with DMA
    > RadeonHD with 3D
    Agreed but onboard gfx is next to useless, and it would benefit to overall OS step ahead, even it would be for start just Radeon 4000HDs. A bit strange situation where all RadeonHDs are supported by paid driver - but in 2D only and one has to add generally slower 9250 to get 3D gfx going. MorphOS has gone further in 3D area, but HD Radeons are anyway next challenge.
    >Yes, on-board network driver for X1000 has been available only for betatesters for ?>over a year.
    True, but is not avail to general X1000 users, so its not out yet. Still additional and slower PCI card has to be used, not to mention more cables.
    > mem card onboard
    >Okay.
    Which is essential as it can boot both AmigaOS, Linux and even could MorphOS but is not visible from AmigaOS. Sad and strange since its nice move to have it.
    I understand the limits, but even use of it as separate VM could be great and benefitial - e.g. running Linux from kind of hardware Hypervisor since X1000/Cyrus support it instead of rebooting to it. That could instantly add usage of Linux apps via such switch, if its possible.
    >FAT? NTFS?
    FAT32 at least, NTFS and EXT4 if possible.
  • »13.08.14 - 13:51
    Yes, obviously.
    According to Olof Johansson, he was promised a board but never sent one.
    >> FAT? NTFS?
    FAT32 and NTFS are already supported by OS4, Linux and MorphOS. That's why I mentioned them.
  • »13.08.14 - 23:13
  • vox
    vox
    >Yes, obviously.
    Well, things were changed a lot thanks to Xenos work. Now almost any PPC64 Linux can be used + Ubuntu can be easily modified with use of package manager to have almost every possible graphic envirovment and programs. Great progress made on that front.
    Why not asking Trevor again if it has purpose of any future development?
    Its not that bad at all once you start using it - its enough horsepower
    to decently run Linux (Libre, Firefox, GIMP ...) and well enoygh for OS4.
    Only trouble is the price, but that seems to be small market economy.
    >> FAT? NTFS?
    >FAT32 and NTFS are already supported by OS4, Linux and MorphOS. That's why I >mentioned them.
    Well, not really. To best of my knowledge, you cannot format a FAT32/NTFS partition from OS4 Partition manager, and neither it can see already made on under Limux partition manager, at least not instantly. If I understand recent progress
    http://amigax1000.blogspot.com/2014/02/filesysbox-ntfs-with-sata-hd-on-x1000.html
    it needs a separate hard drive. Or at least was used in that example. HAve to admit haven`t tried that on my own. But even if it needs a separate drive it is better then nothing.
    How does MorphOS do on that front, a common data partition is helpful?
  • »13.08.14 - 23:30
    > How does MorphOS do on that front [...]?
    AFAIK, no separate drive needed for FAT32 or NTFS, but may depend on used partition layout (RDB, APM).
  • »14.08.14 - 11:08
  • vox
    vox
    Good, another nice to see feature of MorphOS. As far as I have read, it can also boot from PFS if inserted in RDB, which is also nice feature. I wonder how better is that IceFS http://blubbedev.net/icefs/ compared to PFS/SFS/FFS2?
    (Just planning future partitions and file systems since I would like to have Xenos Linux too and shared data partition on an SSD)
  • »14.08.14 - 19:42
    Yes, if you mean the MorphOS system partition, not the boot partition with the boot.img file. But this only works on Pegasos and Efika 5200B (and Sam460 in future I guess) as the Mac OpenFirmware doesn't know RDB.
    Linux for the Sam460 is done by Spectre660, not by xeno74.
  • »15.08.14 - 08:08
    "We sell boards also outside the Amiga market even if Amigans are the most of our customers."
    http://www.retroplanet.gr/content/interview-acube-srl-%CF%83%CF%85%CE%BD%CE%AD%CE%BD%CF%84%CE%B5%CF%85%CE%BE%CE%B7-acube-srl
  • »19.09.14 - 15:41
    "The X3500 lives in silicon but we only have a few units for internal testing."
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=39529&forum=33#744691
  • »09.11.14 - 22:45
    Piru
    Posts: 576 from 2003/2/24
    PFS3 has been included in the boot.img since several MorphOS versions, now. Thus PFS3 will also works for Macs. Naturally the boot.img partition must be HFS still.
  • »09.11.14 - 23:02
    Ah yes, thanks for the correction. I missed (or forgot?) that somehow.
  • »10.11.14 - 00:19
  • vox
    vox
    If I understood the AEON development line well, its a bit stange they go for high end dual/quad core model since AOS supports no SMP at all ... I suppose since they might be developed around similar board, that miking will start with high end board. Acubes policy of at least reducing costs a bit sounds more reasonable.
    Its even mentioned X5000 might be launched with OS 4.1 Final, with same future license of OS 4.2, so one more beta ... MorphOS policy of going for fully supported board (like SAM460ex/cr and all past models) is way more reasonable and less harassing to the users. People still have to use two Ethernet cards and even two graphic cards to make best of use of Linux and AmigaOS 4 on X1000 ... and even two sound cards in early days.
    X3500
    P3040 Dual Core 1.5Ghz
    Unknown release date
    £1,400+
    X5000/20
    P5020 Dual Core 2.0Ghz
    4Q 2014 possibly
    £1,600+
    X3500/40
    P5040 Quad Core 2.4Ghz
    £2,000+
  • »10.11.14 - 00:25
