New SAM460EX
    Posts: 12083 from 2003/5/22
    > Seems it's being worked on for Sam460ex as well:
    > http://gitorious.org/aros/aros/commits/sam460
    > http://aros-exec.org/modules/newbb/viewtopic.php?post_id=72012#forumpost72012
    > http://aros-exec.org/modules/newbb/viewtopic.php?post_id=72034#forumpost72034
    "I did the Sam 460ex port for ACube, but I received little user interest, and have since passed on my development platform to another AROS team member. So, I don't think there will be any Sam460ex updates, at least from me. [...] I do not feel that the PowerPC architecture is commercially viable in the long term (personal opinion here!)"
    http://www.intuitionbase.com/jason_irclog.txt
  • »26.08.13 - 10:30
    > Any further information available on the T1042?
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8473&forum=11&start=66
  • »14.09.13 - 17:59
    >>> https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7001&start=745
    >>> I can imagine that Varisys base the Nemo successor(s) on their VM400 product,
    >>> which would mean that the 2 new A-Eon systems could be a cheaper lower end
    >>> system with P3041 chip running at, say, 1.2 GHz, and a more expensive higher
    >>> end system with P5020 chip at 2.2 GHz, all using the same basic board design
    >>> thanks to the pin compatibility of the chips.
    >> A slide from Trevor's AmiWest 2012 presentation (direct link, Youtube) reads like this:
    >> "Future PowerPC Possibilities
    >> - e500mc : 32-bit, quad-core - Mid-level machine
    >> - e5500 : 64-bit, dual-core - Power machine
    >> This goes very much in line with my speculations above. A quad-e500mc chip
    >> (running at 1.5 GHz, which Trevor mentions in his talk) would mean either the P3041
    >> or the P4040 (P2041 wouldn't be pin-compatible) [...]
    > Apparently, the P3041 is more likely than the P4040 to be able to share a motherboard
    > design with the P50xx:
    > http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=37074&forum=14#693507
    "A-EON Technology commissioned Ultra Varisys to create a new generation motherboard, codenamed Cyrus Plus, built around Freescale’s P3 and P5 QorIQ series of PowerPC processors. [...] The board is pin compatible with several 64-bit Freescale QorIQ CPUs including the P3 P3041, an e500mc quad-core CPU running up to 1.5 Ghz and the P5 series P5020, an e5500 dual-core running up to 2.0 Ghz. The P5040 quad-core CPU which operates up to 2.4 Ghz should also be compatible."
    http://www.a-eon.com/18-10-2013-3.pdf
    Maybe someone should tell A-Eon that the e500mc core is not a 64-bit core but a 32-bit one :-)
    "3 New AmigaOne Computer Systems
    AmigaOne 3041, 5020, 5040
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=38284&forum=2&start=20#719651
  • »19.10.13 - 22:48
    Addendum:
    > about native AROS/PPC on the X1000:
    > "AROS is now running on PPC SAMs & Sam Crow has said he would see about
    > getting it going on the A1 & X1000, something I asked about at Amiwest.
    > http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=36695&forum=16&start=120#686212
    "that aros guy [...] said that iff anyone would lone him an xone1000 then he could do aros to ppc easy and that it could be implanted to os 4.0 way use time on that when hyperion is allso using recorse on that all ready now"
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=38284&forum=2&start=40#719698
  • »20.10.13 - 01:52
    > "Cyrus is the MicroATX board [...] and Cyrus+ is full ATX just like the current X1000."
    > http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=37872&forum=16&start=20#711574
    Seems like the mATX variant has been dropped for good and only the ATX variant will make it:
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=33223&forum=14&start=700#720342
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=33223&forum=14&start=700#720380
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=33223&forum=14&start=700#720382
  • »27.10.13 - 00:57
  • vox
    vox
    Posts: 524 from 2003/11/25
    Dreamcast270mhz wrote:
    http://www.sam4x0.com/sam460ex.html
    * flex-ATX form factor (21.6 x 17 cm)
    * 8 layers PCB
    * AMCC 460ex SoC ? upto 1.066 Ghz
    * max 2 GB DDR2 Ram ? 200-pin SODIMM up to 533 Mhz
    * Silicon Motion SM502 embedded MoC (audio/video) max 64Mb gfx Ram
    * Audio 5.1 Realtek ALC655 codec
    * PCI-express 4x lanes slot (16x mechanical connector)
    * PCI-express 1x lane slot (* check notes)
    * PCI slot, 32 bit, 66/33 Mhz, 3.3V
    * 1x SATA2 port (* check notes)
    * 6x USB2 EHCI/OHCI ports
    * 2x 10/100/1000 Ethernet ports
    * Lattice XP2 FPGA with 80 I/O pins expansion connector (optional)
    * UMTS/GSM module (optional requires add-on card)
    * 512 MB NAND Flash (optional)
    * integrated SD card reader
    * RTC clock
    * Serial port, 8-wires
    * I2C and SPI/I2C buses
    * passive cooling
    * U-Boot 2009.08
    Me wantee
    Hope soon MOS will be out for SAM460ex.
    Will it support onboard sound, gfx and FPGA or will it require external ones?
    What could be use of NAND Flash and how much does it cost?
    Onboard SATA is embarrassment since its 1 device only.
    Lame PC with AmiKit XE
  • »03.03.14 - 01:24
  • vox
    vox
    Since X1000 is publicly declared not to be MOS target due to CPU and other limits of Nemo design, will Cyrus be of any interest?
  • »03.03.14 - 01:43
  • vox
    vox
    According to A-Eon, the X1000 will only be sold as complete system, i.e. full setup including OS4 pre-installed.
    Interesting, just like MOS Team said SAM460ex NEVER, now AEON sells Nemo board, sadly after I purchased the whole system. My calculation is that I could save 30% of money if I was to build system in my own country. Moreover, Cyrus was introduced rendering Nemo obsolete - correcting X1000 biggest gap and that is low CPU performance. Sadly its again two versions of Cyrus with CPU soldered instead of one board with changeable CPU.
  • »03.03.14 - 08:21
  • vox
    vox
    > I'm not worried about the X1000 processing capability. [...] I'm sure if I bought a 2.0 GHz
    > 7448 processor for my Powermac, it wouid esily outperform the X1000
    MPC7448 @ 2.0 GHz (overclocked) vs. one core of PA6T-1682M @ 2.0 GHz would be an interesting comparison. It might not come out as clearly as you think, maybe even the opposite way :-)
    > I see no advantage to the implementation they're making with the X1000 (Xena).
    > [...] I don't understand A-EON's intent (with their XENA design).
    Here I'm completely with you. XCore/Xena on Nemo makes no sense to me. Their intention might be to offer something they can pretend to be resembling the old Amiga custom chips in philosophy (see Hyperion stating that Xena, "in true Amiga tradition, provides the AmigaOne X1000 with a custom chipset"), which I consider misleading.
    PA Semi is low power desktop type of G5 CPU with high L1 and L2 cache, FPU, Altivec and memory transfer performance. So G4 would beat it instantly. However, Nemo board is ahead of any G4 board. If looking performance per wat, PA Semi is a winner.
    It seems Pa Semi on Nemo is downclocked to 1.8GHz from 2Ghz, so its now question how to make additional 10% clock boost (jumpers, software overclock?)
    It turned out poor X1000 booting performance was partially caused by slow CFE firmware but also its setting to wake CPU at 500Mhz only (!!!!) that comes as default (!!!!).
    Not to mention OS4 doesn't support nearly half of board features now. So its more Linux machine in practice, even it has great potential and I found decision not to port MOS as sad. That is why I now have SAM460ex on table.
    XCore is not UNUSABLE chip, but since it doesnt have Linux PPC Tools and OS4 one are early, plus you need XORRO card + hardware work on it + programming with no visual tools - they have made it far too complicated. But it can do things like SMART HOME CONTROL.
    A real DSP on board would be way more Amigish, like Falcon had.
    And they did false advertising with its comparison to Transputer
    and adding more Xena cores (how when Xorro isn`t it? Via USB? PCI?) for more
    additional power. Sadness to make baby be born and not care about it.
    [ Edited by vox 03.03.2014 - 08:28 ]
  • »03.03.14 - 08:25
    Posts: 2242 from 2003/2/24
    The nemo ain't underclocked, PASemi overhyped their 1.8GHz CPU as a 2GHz part.
    As to comparing it to a G4, allready done my 2x1.8 Quicksilver won over tommysammy's X1000 in a Blender test.
  • »03.03.14 - 08:37
    Yasu
    Posts: 1724 from 2012/3/22
    @Kronos
    Do you have the numbers somewhere? I would love to see them.
    My MorphOS blog
  • »03.03.14 - 09:20
    I don't think the MorphOS Team has any problem with the PA6T per se.
    It's not so much about the board design, I believe.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7183&start=858 ;-)
  • »03.03.14 - 12:20
    > Cyrus was introduced [...] correcting X1000 [...] low CPU performance.
    CPU performance comparison between QorIQ P3/P5 and PA6T, especially running under OS4, remains to be seen.
    It's 3 versions:
    - X5000/40 with P5040
    - X5000/20 with P5020
    - X3500 with P3041
    QorIQ chips come in BGA packages, so they must be soldered to the board. Only possibility to have them changeable would be by putting them on a CPU module such as COM Express.
  • »03.03.14 - 17:29
    Actually, the PA6T-1682M was originally (i.e. before becoming embedded part) intended to be a notebook type CPU.
    > of G5 CPU
    "G5" is usually considered as belonging to PPC970 microarchitecture family. However, the PA6T is a unique microarchitecture of its own, developed from scratch.
    No, according to Varisys and A-Eon it isn't:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7183&start=472
    I think it supports more than half.
    > XCore is not UNUSABLE chip [...]. it can do things like SMART HOME CONTROL.
    Which, as I said, would make no sense to me on something like the X1000.
    Atari computers are "Amigish"? Interesting note :-)
    Let's see what "they" actually claim with regard to Transputer:
    "XMOS calls it "Software Defined Silicon", we call it 'Xena' [...]. It's the inheritor of the 'transputer' concept [...]. [...] you might have a Xorro board with an array of additional XMOS chips on, connected together to allow highly multi-threaded applications to run in parallel, in a similar fashion to the famous Transputer concept, the predecessor of the XMOS technology."
    http://www.a-eon.biz/nemo.html
    I can't really see anything "false" in these claims.
    http://amigakit.leamancomputing.com/catalog/product_info.php?products_id=1135
  • »03.03.14 - 18:09
  • vox
    vox
    > of G5 CPU
    True, but actually all G designations are Apple designations for chip generation, and dont exist. Its kind of PentiumPro or 64-bit modern arhitecture designation.
    At least I download Mint PPC G5 64-bit and it does work on PA Semi.
    PA Semi is great chip, sadly I have just its only
    Well I don`t believe them a bit. My chip is clocked at 1.8Ghz and originally it was introduced as 2Ghz only. Its now possible to buy it at 2Ghz at selected dealers.
    http://forum.hyperion-entertainment.biz/viewtopic.php?f=33&t=2199
    Trust me, less then half. DOnt let me count em.
    It can make sense if you make use of it, sadly its not boosted in any proper way. My hardware boys find interesting possible uses, but its MUCH MUCH hustle.
    Falcon is. more then crippled A600, A1200, A4000 and CD32.
    Don`t let me find all adverts from that time.
    I have wrote only review of Xena and X1000, thanks.
  • »04.03.14 - 11:01
      a) the Falcon is just as crippled as A600 and A1200.... 16bit bus on a 030?? WTF !!!
      b) all P6T are 1.8 anything 2.0 is overclocked
      c) learn proper quoting!!
    • »04.03.14 - 12:02
      KimmoK
      Posts: 102 from 2003/5/19
      To my understanding it is not possible to be bought as 2Ghz chip, because all chips ever manufactured were 1.8Ghz parts (run also at 2Ghz, though, but only as overclocked a little).
      (you could sue those marketing those 2Ghz chips perhaps)
      I try.
      >CPU: PA Semi Dual-core PA6T-1682M, nominal 2.0GHz (1.8GHz standard) PowerISA™ v2.04+
      Supported as well as existing OS can do it.
      (Second core is not supported by AOS4 as AOS4 is not capable to do SMP yet. And IIRC, GCC for AOS4 does not yet fully optimize for PA6T.)
      >4x DDR2 RAM slots
      >10x USB 2.0
      >1x Gigabit Ethernet
      >2x PCIe x16 slots (1x16 or 2x8)
      >2x PCIe x1 slots
      >2x PCI legacy slots
      All supported.
      >2x RS232
      I think they are supported.
      >1x Xorro slot and xena
      Supported in some ways (similarly as the FPGA of SAM?)
      So far no developer has done anything signifficant with it and one can not blame a-eon for that I think.
      Other supported/in use things are:
      Onboard SATA2(not perfectly IIRC), audio,
      GPU is poorly supported, only in 2D+compositing when AOS4 is used.
      There is no 3D driver for modern GPUs on PPC amigalikes.
      Not sure if onboard PATA is supported.
      Anyway, it would be nice to see the lest of the another half of HW features that are not supported.
      LOL!
      Btw PA6T has huge DSP performance via Altivec. And xena can do DSP functions also (just inferior when compared to Altivec capabilities).
      xena is a bridge chip. One can use it to do things like bridge to A1200 trapdoor connector (like original eyetech/AInc idea was). (I'm sure no one will do that bridge) Another example would be to bridge legacy ports via xena and the available xorro prototyping board.
      To my understanding xcore links are available on the xorro slot. One should be able to add matrix of xcore chips there.
      and...
      As long as AOS4 SW is not capable of using multiple cores, but capable of using Altivec of PA6T, Cyrus is not much faster.
      I think that would require a CPU card. And it would make Cyrus more expensive.
      And there is three cyrus versions in the plans. x3500, x5000/20 and x5000/40.
      (I think they should forget the x3500, though ... unless they manage to come close to SAM460 price)
      IMO: x1000 is great HW. Only too expensive for me and for (too) many others.
      [ Edited by KimmoK 04.03.2014 - 15:30 ]
      :-x :-P 8-)
    • »04.03.14 - 14:09
      boot_wb
      Posts: 874 from 2007/4/9
      This keeps coming up, and I've yet to see a reason why this is something for which one would choose X-Core/Xena/Xorro (I'll just stick with 'X' from now on).
      Sure, it's possible, but why is it desirable? In what way does this utilise X's 'special properties (low latency, multithreading, programmable, high bandwidth CPU connection)? How useful are these strengths in home automation (lighting, thermostatic, intruder detection, communication, audio/video switching, etc).
      It really confuses me every time this is mentioned.
      Sure, you can probably find something useful for it to do, but something that justifies its existence on the board in the first place?
      Why is it a) there, and b) connected to the CPU like that. What practical application does that enrich above sticking it on a PCI card and calling it an 'option'?
      www.hullchimneyservices.co.uk
      Windows free since 2011!
    • »04.03.14 - 16:00
    • vox
      vox
      Well, yes 16 bit buts is a limit, not a first time for Atari,
      but in its era, Falcon is advance over TT, while A4000 is
      hardly an advance over A3000 if A3000 had AGA.
      You are knowledgeable person, all PA Semis were 2Ghz
      http://arstechnica.com/uncategorized/2007/02/8828/
      http://www.pcworld.idg.com.au/article/171883/startup_launches_its_first_power-efficient_chip/
      http://www.google.rs/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CD8QFjAC&url=http%3A%2F%2Fwww.hotchips.org%2Fwp-content%2Fuploads%2Fhc_archives%2Fhc18%2F2_Mon%2FHC18.S2%2FHC18.S2T1.pdf&ei=HwYWU5bLLePD4gTP14H4Bg&usg=AFQjCNF_TJpe7b-6qxepLvp2gxiJVbS9MQ&sig2=AT8m9NA-A5VWPqcpgJYIhA&bvm=bv.62286460,d.bGE
      Board could have better quoting system. But I can do old school >>> BBBS style.
    • »04.03.14 - 16:59
    • vox
      vox
      I try.
      USB 3.0 not supported
      3D graphics of my RadeonHD not supported
      1GB VRAM only 256MB
      4MB DDR2 only 2MB
      SD Card not visible
      Second core not visible
      Onboard ethernet NOT SUPPORTED
      Xena/Xorro - basic from AMigaOS, none from Linux
      Only SATA/IDE/PATA, USB 2.0, 2D and AudioHD are.
      CFE will not be updated, reads only FAT32 and ETX3.
      This is BIG prob.
      Anyway, it is great HARDWARE, way better then SAM460ex
      but yet SAM460ex is way better used from software point of side.
      Only LInux on X1000 makes it usable machine.
      Now, since there will be no MOS on X1000, lets go back to SAM460ex
      [ Edited by vox 04.03.2014 - 17:05 ]
    • »04.03.14 - 17:03
      And if pigs had wings...
      The Falcon had plenty HW bodged together with 0 SW support, AGA in the A4000 was useable from day one, and a 040 was no CPU to frown upon at that time.
      http://www.google.rs/url?.......................
    • »04.03.14 - 17:06
      >> scratch.
      "G5" is the name Apple has used only for the PPC970 family, which the PA6T doesn't belong to (even though the PWRficient was originally intended to be for the Apple notebooks what the PPC970 was for the Apple desktops and workstations). So I wouldn't call the PA6T a "type of G5 CPU".
      Sorry, I don't understand this, and especially not as a reasoning as to why the PA6T should be called a "G5".
      > Mint PPC G5 64-bit [...] does work on PA Semi.
      The PPC64-compiled *userland* running on top of the Linux kernel works on any PPC64 CPU, but you need a special PA6T Linux kernel as the PPC970 Linux kernel doesn't run on the PA6T as is (nor on any other PPC64 CPU). That should tell you that the PA6T is no "G5".
      No, it was a company that was purchased by another company. The chip is called PWRficient PA6T-1682M (full name).
      Fortunately what you do or don't believe doesn't change the facts. I for one trust Varisys in their statement, and EETimes agrees with that:
      "Apple sent a letter to the DoD saying it will assure production of the 1.8 GHz PWRficient processor for three to five years, said one source who saw the letter but asked not to be named."
      http://www.eetimes.com/document.asp?doc_id=1309557
      No, the PA6T was introduced (read: announced) as running *up to* 2.0 GHz, but they didn't follow through on that announcement. That's what Varisys and A-Eon have said in the link I gave you, and what Kronos has told you right here in this thread.
      No, it's not. It's still running at 1.8 GHz. Trevor even clarifies that right in the thread you link to. May I propose that you go out of your way and read your own link?
      > Trust me
      I won't, that's for sure. You utter way too much false statements and also outright nonsense ad nauseam, even after confronted with evidence, for me to trust you.
      Please do count them. Else I won't believe you but instead maintain my opinion that OS4 supports more than half of the Nemo features.
      Your statement that the Atari Falcon is more "Amigish" than Amiga 600, Amiga 1200, Amiga 4000 or Amiga CD32 is laughable at best. It may work if you define Atari as "Amiga" and Amiga as "non-Amiga", but why should anyone do such nonsense? Amigas are "Amigish" by definition, that's the meaning of the word. The Falcon is clearly "Atarish".
      >> Let's see what "they" actually claim with regard to Transputer: [...]
      Please do, else I will continue to refute your claim of "false advertising with its comparison to Transputer".
      Sorry, I don't understand.
    • »04.03.14 - 23:12
      >>2x RS232
      > I think they are supported. [...] Not sure if onboard PATA is supported.
      They are both: http://amigaworld.net/modules/news/article.php?storyid=6345
      GPU is no Nemo board feature anyway.
      You can use a fully supported Radeon card with R200 GPU in a PCI slot. It will be slowish due to 32-bit 33 MHz bus, but it will work.
    • »04.03.14 - 23:35
      > A4000 is hardly an advance over A3000 if A3000 had AGA.
      But the A3000 doesn't have AGA, right? So what's the logical conclusion as per your own statement?
      No, the PA6T was not. It was and is a 1.8 GHz part which is possibly overclockable to 2.0 GHz.
    • »04.03.14 - 23:43
