New SAM460EX
    Posts: 12408 from 2003/5/22
    > It's apparent that VSX is an extention of VMX. I got confused because those few times
    > I read about VSX, I missed -or they omitted- VMX mentioned. And until now -that is
    > until you made me read more about it :) - I thought they were distinctive units.
    I found some more information there:
    http://www.power.org/events/Power7/Performance_Guide_for_HPC_Applications_on_Power_755-Rel_1.0.1.pdf
    Pages 7/8:
    "A new single instruction multiple data (SIMD) instruction set called VSX is introduced in the POWER7 processor. This is in addition to the AltiVec SIMD instruction set which was previously introduced in the PPC970-based system, the JS20 blade server."
    Page 69:
    "The Vector-Scalar floating point eXtension architecture (VSX) has been developed by IBM to extend SIMD support to include two independent 2-way-SIMD double precision floating point (FP) operations per cycle. The Altivec SIMD features are a subset of VSX. [...] For POWER systems, the "VSX" term has been used to highlight the double precision arithmetic instructions supported by the POWER7 hardware, with "Altivec" reserved for the older 32-bit precision arithmetic SIMD support."
    Page 71:
    "The POWER7 architecture continues to support the Altivec instruction set, and extends support to double precision floating point operations with the VSX instruction set. The VSU (Vector Scalar Unit) is the hardware that implements the Altivec, VSX and scalar floating point instructions. There are no longer separate scalar FPUs in the POWER7 core. [...] The VSU is the combination of the Altivec execution unit and the 4 FPUs. It is divided into two independent pipes, each of which can execute one instruction per cycle. Each pipe can independently execute a scalar double-precision FP op or a SIMD double-precision FP op. All SIMD operations are on 16-byte vectors of data. Mimicking the behavior of the original Altivec unit, pipe0 handles the simple FX, complex FX and 4-way SIMD single-precision FP ops and pipe1 handles the Altivec permute ops."
    Page 83:
    "While Altivec and VSX have differences in programming details, they have similar criteria when it comes to deciding how to convert a candidate (scalar) program to exploit SIMD instructions to increase performance."
    Page 86:
    "The vector multiply-add intrinsic for double precision arithmetic (VSX) is the same as for single precision (Altivec). Not all corresponding VSX and Altivec instructions share the same intrinsic."
    Taking these notes into account, my conclusions are as follows:
    1. VSX and VMX/AltiVec are really two distinctive physical units.
    2. The features of VSX represent a superset of the features of VMX/AltiVec.
    3. The VSX instruction set is *not* a superset of the VMX/AltiVec instruction set. In fact, the instruction sets are different (with some overlapping). That means that a processor implementing VSX does not necessarily implement VMX/AltiVec. A program using VMX/AltiVec instructions will therefore not run on a processor that implements just VSX, but can be changed on source code level to use VSX instead.
    Any objections? ;-)
  • »06.08.10 - 14:24
    >The VSU (Vector Scalar Unit) is the hardware that implements the Altivec, VSX and scalar floating point instructions.>
    I don't know, Andreas. From that statement, I would gather that all floating point operations are performed by one hardware unit designed the execute all three of sets of instructions.
    While these instructions could be implemented separately, they don't appear to have been in Power7.
    Therefore, VSX isn't a superset of the VMX/Altivec instructions, and would appear to act like many of the instructions added over the years to X86 processors.
    There are many old X6 instructions (including many old math coprocessor routines) that remain in the architecture (and allow for backward compatibility) that have been rendered irrelevant by newer, more powerful instructions.
    While a new PPC processor might be designed to only support VSX, it seems unlikely that IBM would want to do that.
    You are certainly right in your assertion that VSX is a new group of instructions with only some overlap of older Altivec instructions. That limited duplication of functions and the fact that all former instructions are implemented in Power7 would indicate that IBM wants to continue to support full backward compatibility (as they have done with revisions in the past).
    I don't know what you define as a superset, but if Altivec is equivalent to Intel MMX , then VSX can be see as an analog of the later SSE instruction sets.
    [ Edited by Jim on 2010/8/10 21:28 ]
  • »10.08.10 - 17:27
    One question you might be able to address, Andreas. Why does everyone discount the idea of Power7 being moved into mainstream markets? When Apple required something more advanced than the G4 level processor, the processors that were eventually designated as G5s were designed incorporating features from higher end Power systems. Even the mass market Cell architecture gains some power from similar incorporations.
    If IBM were again to target a large consumer market, why wouldn't they base the product on their most powerful design yet? Isn't that sort of what they've done in the past?
    [ Edited by Jim on 2010/8/11 2:19 ]
  • »10.08.10 - 17:48
    Read further: "The VSU is the combination of the Altivec execution unit and the 4 FPUs." I read it as the VSU consisting of smaller (sub-)units like for instance the AltiVec unit. But maybe I'm just reading it wrong and it means that the VSU is now what "the Altivec execution unit and the 4 FPUs" had been before, i.e. in former implementations like POWER4/5/6 or PPC970.
    Yes, that's what I concluded, regardless of VSX and AltiVec being two distinctive physical units or being both executed by just one single unit.
    Yes, but it's not only IBM I'm looking at. See (last sentence):
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7001&forum=3&post_id=74716#74716
    http://en.wikipedia.org/wiki/Subset#Definitions
    That sounds reasonable.
  • »10.08.10 - 20:45
    > mainstream markets?
    Is anybody really doing this? :-) While the POWER7 "as is" is definitely not suited for our market(s) a trimmed down (features, power usage, cost) version surely could be. That's exactly what IBM did with the POWER4 after all.
    > G6s were designed incorporating features from higher end
    > Power systems.
    I take it you mean "G5", not "G6". And yes, the PPC970 aka G5 is a trimmed down POWER4.
    BigGun says that the Cell PPE architecture (while being way older, so it's probably the other way round) is related to the POWER6 architecture:
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=29336&forum=2&start=180#504967
    Yes, exactly. But the real question is: Are IBM to target a large consumer market ever again with Power Architecture (not counting developments solely done for Microsoft or such)? :-)
    However, there is something going at IBM regarding alleged trimmed down POWER7 cores:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6268&forum=11&post_id=75659#75659
    I'm not sure if The Register is right though, because POWER7 is an out-of-order design while the A2 seems to be in-order. But the A2 core based PowerEN processor doesn't seem to be suited for our market(s) either, unfortunately.
  • »10.08.10 - 21:15
    No, I think I've seen mention of the A2 before and the impression I got was that IBM had designed it for specialized tasks like the network processors that Freescale has focused on.
    Lately it seems like a lot of the PPCs introduced aren't really well suited to our market. Its become hard to argue with AOS fans about the PA6T (not that I try to), when floating point support is so weak on a large number of other new PPCs that have been introduced.
    Thanks for pointing out the error on that post. I corrected it as, obviously, there was never a G6.
    [ Edited by Jim on 2010/8/11 2:20 ]
    [ Edited by Jim on 2010/8/11 2:45 ]
  • »10.08.10 - 22:18
    >> Over there on the Bunny minator claims:
    >> "AMCC cancelled Titan"
    >> http://moobunny.dreamhosters.com/cgi/mbmessage.pl/amiga/174889.shtml
    >> Do you think that could be true?
    > No Applied Micro's not about to give up on Titan.
    There's again an interesting posting by minator:
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=32137&forum=2#574839
    Some quotes regarding Titan:
    "Titan is [...] a completely new core design."
    I'm eager to see where this statement leaves Lauterbach's hint that Titan is PPC450 based.
    "Titan has been killed. Titan was actually designed by a company called Intrinsity*. Apple bought Intrinsity and suddenly Titan is no more. [...] *I went to a presentation by Intrinisity where they said this."
    Here we have minator's "Titan is dead" claim again.
    "The new Titan core design will not die, it will reappear at a later date."
    That's a confusing one for me. Just before he said that Titan was killed, to say one line further down that it's not been killed at all. Do I miss something here?
  • »12.08.10 - 09:11
    No, you're not the source of this confusion, minator does appear to say Titan has been killed and that it will reappear later. He seems confused.
    His confusion over Intrinsity's part in the designing of Titam is understandable
    If your follow Applied Micro's press releases, you would be under the impression that Titan's low power draw 90nm construction was a result of AMCC's licensing of Intrinsity's Fast14 Technology.
    Intrinsity's own press releases lay claim to far more responsibility in the design.
    http://www.marketwire.com/press-release/Intrinsity-Nets-2-GHz-4000-DMIPS-PowerPC-FastCore-733747.htm
    Since the Titan core is not a stand alone product, and it has already been announced as part of an SOC to be produced this year, I don't think the core is dead.
    Too much has been speculated based on limited information coming from sources that, primarily, appear to want to emphasize their role in developing the product.
    Intrinsity's has a right to be proud of its innovative gating and timing designs. These schemes are unique and are responsible for allowing the 90nm processor to scale up its clock speed while remaining a low draw component.
    However, AMCC and Intrinsity may be overplaying the actual changes in architecture. Except for higher clock speed, Titan doesn't appear to offer any radical improvements over AMCCs current processors. Their claim that "No other 32-bit PowerPC core even comes close to the 2.0 GHz 4000-plus DMIPS performance of this core" seems questionable in light of the MIPS figures you've posted.
    The comparisons to AMCC's PPC460 core may turn out to be valid. The designers of this chip had to start somewhere and considering both companies past histories, an evolutionary design seems more likely than a completely revolutionary approach.
    Just getting Fast14 incorporated into the design would have been difficult enough.
  • »12.08.10 - 15:33
    Thanks. I'm glad it's not me missing something obvious. Yet I'd like to know what he really meant. I think he can't seriously contradict himself in such an obvious way that it's almost frightening ;-)
    Yes, that's the impression I've been under.
    Indeed. There appears to be some kind of coherency gap between the two press releases.
    According to Applied Micro's October 2009 press release the APM83290 has been supposed to enter production in Q1 2010. This means that this SoC should now have been in production for at least 4.5 months already. So far I haven't spotted any statement regarding production delay let alone any existing device using this SoC. With each day passing without any new information minator's assessment becomes more and more probable, I fear.
    Without new information from either Intrinsity (unlikely because of having been bought by Apple) or Applied Micro there's not much more we can do except to speculate ;-)
    Yes, depends on the definition of 'close' I guess. At 1.7 GHz (maximum clock rate as specified by Freescale) the e600 delivers 3910 DMIPS. It seems that about 2% less performance doesn't qualify as being 'close' ;-)
    As I pointed out, Lauterbach lists the Titan core based APM83290 as being "PowerPC 450". On the other hand, they list both the PPC460EX and PPC460GT as being "PowerPC 460", ignoring the fact that these two SoCs actually have a PPC440 core. So maybe Titan was developed from the PPC460 core even, and Lauterbach got that wrong as well. Should the APM83290 really be based on an upclocked PPC460 core then there's the question what the APM821xx (which should have been in production for at least 1.5 months according to the announcement press release, but is only really sampling for now) was needed for in comparison.
  • »12.08.10 - 18:23
    I thought that when they announced the APM83290 they were moving from sampling to full production rather quickly (faster than many larger companies).
    Perhaps the delay reflects a needed revision in their die. That could certainly account for a significant delay. Its difficult to know in the vacuum that surrounds this product. Applied Micro has never even mentioned this core on their website and most of the information currently available has come from press releases.
    No one outside of their AMCC's NDA has any really hard data on this product. At least when Freescale announced the e5500 they published a block diagram showing the major parts of that core.
  • »12.08.10 - 18:48
    Less than 6 months for sampling is rather quick, yes. I guess that would have made up for the 2.5 years that passed from the announcement of the core to the announcement of the processor based on that core ;-) Btw, both the APM801xx and APM821xx are/were supposed to have an even shorter sampling phase of no more than 3 months according to the announcement press releases.
    Apart from both the Titan press release (May 2007) and the APM83290 press release (October 2009) on appliedmicro.com there're some old product selector guides mentioning Titan:
    http://www.appliedmicro.com/Embedded/PPC-ProductSelectorGuide_v7-01.pdf (October 2007)
    http://www.appliedmicro.com/Embedded/ppc_psg_7%2002_111607web.pdf (February/March 2008)
    http://www.appliedmicro.com/Embedded/ppc_psg_7.3_092908.pdf (September 2008)
    See the roadmaps on each of these document's page 3 (and compare to the "roadmap" on page 4 of the most recent product selector guide (April/May 2010)).
    I think the presentation PDF files scattered around the web and especially on power.org are much more informatory (including Titan block diagram) than the press releases:
    http://www.google.com/search?q=site:power.org+amcc+titan+filetype:pdf
    The Intrinsity press release you linked to comes with a Titan block diagram (on the top right, but the link to the bigger version of the image is dead).
    Edit:
    Now I know what minator refers to and it's all making sense now. It's true: Titan is dead :-( Seems we're some weeks behind, Jim ;-)
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6268&forum=11&post_id=75800#75800
    [ Edited by Andreas_Wolf on 2010/8/13 2:01 ]
  • »12.08.10 - 20:35
    jcmarcos
    Posts: 1178 from 2003/3/13
    Exactly. I think Jim has "too much" faith in POWER coming back to consumer space. In this business, when something is abandoned, it NEVER comes back. Well, go tell that to Escom, Gateway, Bill McEwen...
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6268&forum=11&start=60#75659
    That URL doesn't show me the post you want. It might be that I chose "most recent at top" in my MorphZone forum preferences. But this different URL worked:
    See that "75659" now as the parameter "post_id", instead of the hash (#).
  • »13.08.10 - 05:16
    > POWER
    Just a small hint at terminology: POWER is IBM's server CPU microarchitecture implementing the Power ISA (instruction set architecture) launched in 2006 as successor to the PowerPC ISA. See:
    http://en.wikipedia.org/wiki/Power_Architecture#Glossary
    Yes, that's the reason. Thanks for pointing it out. I'll make my internal links more compatible from now on, using your URL pattern (plus fragment identifier).
    The "#<number>" is needed nevertheless because it works as a fragment identifier.
  • »13.08.10 - 08:18
    [quote]
    [quote]ote]
    I'd hate to lumped in with Bill McEwen and those others.
    But to counter, the PPC has not been abandoned. Power 7 exists, PPC derived processors power all three major game consoles, and Freescale has just released a 64bit successor to the e500, thr e5500.
    IBM has a processor based ion the P7 and AMCC is carrying forward a 40nm variant of their Titan core without Intrinsity's Fast14 technology.
    It is even rumored that the next PlayStation portable will be Cell based.
    In what way is this an abandoned technology.
    I don't base anything on faith, these are real developments.
    PA Semi's Pa6T is real enough to power the X1000. Freescales planned e5500 cored products may be fast (Mips) than that processor or Titan.
    Things may have been a little slow, but developments (in PPCs) are actually picking up.
  • »15.08.10 - 01:07
    It's not released yet, just announced.
    That's what The Register claims at least. As I said, I'm not really convinced that PowerEN is really POWER7 based (see in-order vs. out-of-order execution).
    As far as I understand, the new 40 nm core that is supposed to substitute the scrapped Titan core won't be a Titan variant but another core altogether, offering similar features. I'd be disappointed if the undisclosed 40 nm core really is supposed to just be Titan with a shrinkage applied to it to make up for the abandonment of Intrinsity's Fast14 technology.
    That rumour is utter nonsense. The PSP2 will most likely be nVidia Tegra 2xx (ARM Cortex-A9 core) driven.
    http://www.semiaccurate.com/2010/07/14/sonys-psp2-powered-nvidias-tegra-line/
    > processor or Titan.
    In terms of DMIPS the e5500 will *definitely* be faster than the sinked Titan or a single PA6T core.
  • »15.08.10 - 15:28
    As far as I understand, the new 40 nm core that is supposed to substitute the scrapped Titan core won't be a Titan variant but another core altogether, offering similar features. I'd be dissapointed if the undisclosed 40 nm core really is supposed to just be Titan with a shrinkage applied to it to make up for the abandonment of Intrinsity's Fast14 technology.
    Personally, I's settle for a Titan derived processor without Fast14. At 40nm it might scale fairly well. Even a 1.8 Ghz variant could be much more powerful than AMCCs current line.
    Until we see first hand the floating point capabilities of Freescales planned e5500 core, the (DMIPS) disadvantage of the Titan (or its successor) may not be as great as we're assuming.
    More than any other factor, the comparative price of e5500 cored and Titan cored processors and their availability may affect what products each is incorporated into.
    I could see a 1.8Ghz "Titan" based motherboard, if the cost could be kept down, making a nice substitute for Acubes product line or as an alternative to a Pegasos or Mac.
  • »16.08.10 - 01:02
    While the APM83290 was supposed to run up to only 1.5 GHz, the Titan core itself was announced to scale up to 2.0 GHz. I expect a Titan replacement core to not undercut that figure, and the Titan replacement core based processor should really not undercut the 1.5 GHz figure of the APM83290. So yes, 1.8 GHz would be fine for the processor I guess, and you're right that it would definitely be much better performing than anything they have right now, be it officially announced or sampling or in volume production.
    I really don't get your point here. The DMIPS per MHz figures of both the e5500 and the Titan are officially known: 3.0 vs. 2.0. That's 50% more DMIPS per MHz for the e5500. So to get on par the Titan would have to be clocked 50% faster than the e5500, which it is not. Quite to the contrary, the e5500 is announced to scale to a 25% higher clock rate than the Titan (or even 47% if we look at the announced processors based on the cores). That's a 87.5% higher DMIPS performance altogether for the e5500 (and even 120% higher on a processor level).
    Of course that's all assuming that the Titan replacement core will deliver the same DMIPS per MHz figure as Titan, which would be the case if it's really just a shrinked Titan without Fast14.
    > I could see a 1.8Ghz "Titan" based motherboard [...] as an alternative to a [...] Mac.
    An "alternative" to a G4 Mac as in "similar performance", yes.
  • »16.08.10 - 09:02
    My only point was that MIPS as a general measurement is useful, but its not a perfect way to compare floating point power. Without Altivec and sporting a floating point engine thar's twice as fast as its predecessor, how willing pointing point operations compare between the 5500 and the Titan?
  • »16.08.10 - 19:41
    Dhrystone (DMIPS) is a pure integer benchmark. It doesn't measure floating point performance at all. Floating point performance can be measured for instance by Whetstone (MWIPS), LINPACK (MFLOPS) or LAPACK. See:
    http://en.wikipedia.org/wiki/Dhrystone
    http://en.wikipedia.org/wiki/Whetstone_(benchmark)
    http://en.wikipedia.org/wiki/LINPACK
    http://en.wikipedia.org/wiki/LAPACK
    That remains to be seen. All processors from Applied Micro which have an FPU (i.e. some of the PPC440 core based ones and all of the PPC464FP core based ones) deliver 2.0 MFLOPS per MHz in both single and double precision. I've yet to find numeric floating point performance figures for the e5500. All I know is that compared to the e500mc the e5500 has twice the single precision performance per clock and up to quadruple the double precision performance per clock. But I don't have any real numbers for the e500mc either.
    Edit:
    Freescale's e500mc presentation notes that e500mc has "same floating point unit as e300", but which is half clocked in relation to the core clock and thus half performant. So I'd conclude that compared to the e300 the e5500 has the same single precision performance per clock and up to twice the double precision performance per clock. Now we only need the floating point performance figures for the e300 to get the whole picture ;-)
    [ Edited by Andreas_Wolf on 2010/8/17 3:35 ]
  • »16.08.10 - 21:16
    Seems we know at least the name of the Titan replacement core based processor: APM86xxx.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6196&forum=11&post_id=75913#75913
  • »17.08.10 - 00:13
    These figures worry me.
    >(i.e. some of the PPC440 core based ones and all of the PPC464FP core based ones) deliver 2.0 MFLOPS per MHz in both single and double precision.>
    If the Freescale 5500 core produces higher DMIPS but lower floating point performance, how will Titan's descendants look in comparison?
    [ Edited by Jim on 2010/8/26 4:56 ]
  • »17.08.10 - 01:56
    > These figures for the e5500 worry me.
    Why? We (as in "you and me") only have relative figures to other Freescale cores, no absolute ones yet, haven't we?
    > If the Freescale core produces [...] lower pointing point performance
    We don't know this yet, do we?
  • »17.08.10 - 08:44
    No, I guess we get no firm answer until both are tested.
  • »17.08.10 - 19:37
    > the XCGPU you mentioned, Andreas, may be two separate dies
    > under a common heatspreader.
    Seems it is not:
    http://arstechnica.com/gaming/news/2010/08/microsoft-beats-intel-amd-to-market-with-cpugpu-combo-chip.ars
    http://www.eetimes.com/electronics-news/4206424/Microsoft-IBM-Xbox-360-250G-chip
    Edit: added link to another article
    [ Edited by Andreas_Wolf on 2010/8/25 6:36 ]
  • »24.08.10 - 22:53
