Posts: 2026 from 2003/2/24
Quote:kickstart wrote:
jPV wrote:
Well, for me that sounds more like out of vmem issue than network issue :). Have you tried to run OWB on non enhanced screen or screen with less colors or resolution? Or on Ambient screen... or on non enhanced Ambient screen ;)
32mb of gfx memory is not much but i think that is enought for a browser, at least with the same machine tells that runs ok.
It certainly isn't sure. It depends how many screens you have open, in what resolution, depth and layers. On OSX you just have one screen in memory, while on MorphOS you can have several. With enhanced display, every window takes its space on vmem too, so window count affects too and for example when download window opens it might cause some swapping and freezing alone if you're on the limit.
As it was said that command-m keyboard shortcut doesn't work either when freezing happens, I assumed there are several screens open. Maybe OWB on its own screen even.
With big resolutions today, it isn't even sure if one (Ambient) screen fits into 32M with enhanced layers. Ambient disables enhanced mode automatically on my 1600x1200 screen with 32M mini, because it detects there isn't enough memory. And you can't fit too many screens in 32M even with lower resolutions like 1280x1024. 64M isn't that much either if you actively use many screens and want to keep enhanced modes on some.
pOS wrote:
Well, 64 MB graphics ram should be enough to view a simple web page. Nonetheless I tried switching off Enhanced Mode. Doesn't make a difference.
Ok, I wasn't sure if you really have 64M, because you said earlier "MacMini G4/1.4 Ghz, 1 GB Ram, 64 MB VRAM.". It must be 1.5GHz model then...
