Posts: 599 from 2004/11/27
Dragster wrote:
@Fab
On MorphOS2.4 (regged) a download with OWB?goes up and down all the time speedwise.. very similar issue to the one described by other users on this very same thread. So, I'd kindly ask the MorphOS developers to check for issues on the via_rhine ethernet driver at least.
Dragster
well it seems then there is also a problem with the via_rhine.device though I did not notice such with several Pegasos2 in a LAN (using Envoy3) but only noticed it with and on MacMini's also in the LAN. Here the Pegasos2's seem to have stable transfers either LAN or internet which IS NOT the case at all with the MacMini's.
Sometimes I notice the following: on an Pegasos2 I open a drawer which is on a LAN partition where I downloaded software lha archives. In general I double click on the archive and then copy the files to where I need them. The very 1st time I do that (say I've downloaded 5 lha archives) the archive "opens" instantly, then I copy the files and with the "back" button I got back to the list, select the 2nd lha archive and here sometimes (quite often I must say) it takes several 10th of seconds before the archive opens. It doesn't matter if it'a a small or big archive then even very small ones, 200 to 500 kb, take a lot of time.
Similar seems to happen when e. g. copying from or to the Mac Mini via the LAN, sometimes it's fast, 3.5 mb/s, but sometimes it's very slow, only several kb/s..., hm...?
