Posts: 2720 from 2003/2/24
Do you really need the entire samba package? Try if smbfs your needs:
1. Download the
smbfs.lha archive.
2. Put the unpacked smbfs program in your c
3. Read the supplied documentation, which is very straight forward, down to the point, easy to understand, etc.
4. Start the smbfs program with the options that is relevant for you. For instance:
Now you can start the file system. For example, to connect to the file server
called 'sourcery' and the shared 'all' resource it exports, with that computer
being a member of the workgroup 'Arbeitsgruppe', using the login name
'PCGuest' and not providing any password you would enter the following:
Run >NIL: SMBFS Workgroup=Arbeitsgruppe User=PCGuest Service=//sourcery/all
All the options are discussed in the documentation...
MorphOS is Amiga
done right! MorphOS NG will be AROS
done right!
