MorphOS 3.20
    Posts: 3337 from 2003/3/5
    I've used that display before - worked great, although you will have issues with the resolutions you've mentioned, as far as I remember.
    Another issue is its relative hunger for watts.
  • »19.06.26 - 13:49
    Posts: 3 from 2019/10/23
    jacadcaps wrote:
    duga wrote:
    My ethernet interface is not working since upgrading 3.18 to 3.20 on my Sam460ex. How do I reset all network settings?
    Unit is N/A under Network unit statistics. Changing from DHCP to static and vice versa doesn't help. The interface is ppc4xx_eth.device:0, version 50.7 from 24.12.2020
    Try either copying the eth device or netconfig.library from 3.18 and report back. Would help to know which one it is.
    this solved the issue here on my Sam460
  • »19.06.26 - 14:56
    "this" meaning? Do you mean the device or netconfig?
  • »19.06.26 - 15:44
