SUpport imac g5 isight ?
    NewSense
    Posts: 1601 from 2012/11/9
    @ Georg - I don't think your idea is the way I'd like to see this change - to solve the problem, but thanks for suggesting it anyway. ;-)
    It seems to me that it is either a change to the way the iMac Brightness setting is currently functioning or a change to PageStream that bypasses the iMac Brightness Setting of F1/F2 keys by using alternative Function keys.
    For me, as I am so familiar with using PageStream, and that the iMac Brightness setting is so much more recent I would hope the key allocation in MorphOS could be modified to use a keyboard key modifier, like Control, Alt-Option or Command or use less likely to be used Function Keys like F11 and F12? 8-D
  • »21.05.23 - 00:31
    Georg
    Posts: 129 from 2004/4/7
    Well, then happy wait for months/years for next release which may or may not have the change/option you hope for ...
    ... instead of using a little hack/tool which (if it works) (and in the meantime) would do the same right now.
  • »21.05.23 - 03:53
    NewSense
    Having spoken to cyfm it seems the PageStream Function key mapping can be modified using the Script Palette so that a modifying "Special" key (such as Control, or several other key combination(s)) can be added so they do not clash-conflict with the iMac F1/F2 key(s) to set the Brightness level. 8-)
    Hopefully this is an interim solution, as I would prefer to have the original PageStream single 'F' key as usual, rather than a 2 key pressed option, but it does at least free the clash-conflict for the time-being that occurred when I installed MorphOS v3.18. 8-D
  • »22.05.23 - 04:33
    Posts: 607 from 2003/4/11
    Politely ignoring the trolling/rant about a probable delay for a solution due to our update schedules, I will just confirm that this ugly 68K SetFunction() patch won't work anyway as neither the brightness control, nor PageStream5 uses CreateCXObj to install the function key mapping.
  • »22.05.23 - 08:14
    Georg
    Posting source with this gate/trap/whatever stuff (unless beautified by AROS macros)
    would have looked even worse ;-)
    So what about this, then (to have brightness, etc. with ALT + function keys):
    #include <exec/interrupts.h>
    #include <devices/input.h>
    #include <devices/inputevent.h>
    #include <proto/exec.h>
    #include <proto/input.h>
    #include <clib/alib_protos.h>
    #define PRI1 121
    #define PRI2 119
    #define NAME1 "FKEYHACK1"
    #define NAME2 "FKEYHACK2"
    #define QUAL IEQUALIFIER_LALT
    #define SHIFTALTCTRL (IEQUALIFIER_LALT | IEQUALIFIER_RALT | IEQUALIFIER_LSHIFT | IEQUALIFIER_RSHIFT | IEQUALIFIER_CONTROL)
    #define IECLASS_HACK 0x7C
    struct MsgPort *mp;
    struct IOStdReq *io;
    struct Interrupt i1, i2;
    struct InputEvent *ihandler1(register struct InputEvent *ie asm("a0"))
    struct InputEvent *e = ie;
    while(e)
    if (e->ie_Class == IECLASS_RAWKEY)
    int code = e->ie_Code &~ IECODE_UP_PREFIX;
    int quali = e->ie_Qualifier & SHIFTALTCTRL;
    if (code >= 0x50 && code <= 0x59) /* F1 .. F10 */
    if (!quali)
    e->ie_Class = IECLASS_HACK;
    else if (quali == QUAL)
    e->ie_Qualifier &= ~QUAL;
    e = e->ie_NextEvent;
    return ie;
    struct InputEvent *ihandler2(register struct InputEvent *ie asm("a0"))
    while(e)
    if (e->ie_Class == IECLASS_HACK)
    e->ie_Class = IECLASS_RAWKEY;
    return ie;
    void dohandler(int cmd, struct Interrupt *i)
    io->io_Command = cmd;
    io->io_Data = i;
    DoIO((struct IORequest *)io);
    int main(void)
    mp = CreateMsgPort();
    io = CreateIORequest(mp, sizeof(*io));
    i1.is_Code = (void *)ihandler1;
    i1.is_Node.ln_Pri = PRI1;
    i1.is_Node.ln_Name = NAME1;
    i2.is_Code = (void *)ihandler2;
    i2.is_Node.ln_Pri = PRI2;
    i2.is_Node.ln_Name = NAME2;
    if (!OpenDevice("input.device", 0, (struct IORequest *)io, 0))
    struct InputEvent *ie;
    dohandler(IND_ADDHANDLER, &i1);
    dohandler(IND_ADDHANDLER, &i2);
    Wait(SIGBREAKF_CTRL_C);
    dohandler(IND_REMHANDLER, &i2);
    dohandler(IND_REMHANDLER, &i1);
    CloseDevice((struct IORequest *)io);
    DeleteIORequest(io);
    DeleteMsgPort(mp);
  • »22.05.23 - 14:29
    Posts: 2564 from 2003/2/24
    That is almost as much code as my abandoned brightness screenbar module.... (works but has no way to save/load a value).
  • »22.05.23 - 15:12
