X86 Mac mini
    discreetfx
    Posts: 399 from 2003/7/26
    Supporting Intel Mac mini seems like a no brainer for x86 MorphOS to me. I’m not a OS developer though.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »14.10.20 - 14:12
    Posts: 12408 from 2003/5/22
    It would have to be models from 2011, then (see comment #6).
  • »14.10.20 - 14:44
    Posts: 2726 from 2003/2/24
    And moving away from hopelessly old, ancient HW is perhaps *one* of the reasons to migrate in the first place, so...
    Speaking of Mac Mini's, the latest one (the early "Apple silicon" development system) is actually based on *ARM*! Food for thought...? ;-)
  • »14.10.20 - 18:52
    Yes, see comment #2.
    Yes, see comment #1.
  • »14.10.20 - 20:17
    discreetfx
    I’m glad to report that I was able to bring one of my Mac mini’s back from the dead.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »15.10.20 - 14:53
    discreetfx
    I spoke too soon. I can’t get network access to work.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »15.10.20 - 15:53
    Samurai_Crow
    Posts: 172 from 2009/12/10
    I have a spare Mac Mini PPC without a PSU. If you have a working power supply it should work. It appears to be an earlier model than my silent upgrade model. Are you interested? (I'll pull it out and install MorphOS unregistered first if you like.)
  • »15.10.20 - 19:44
    discreetfx
    What’s the price for that mini?
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »15.10.20 - 23:08
    Samurai_Crow
    I'd better test it first. If it works, I'll sell it to you.
  • »16.10.20 - 01:00
    discreetfx
    Cool, thanks, these things are getting old.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »16.10.20 - 01:24
  • ASiegel
    Posts: 1387 from 2003/2/15
    Bill, before you buy another Mac mini, please note that you might still have networking issues even after you buy a similar model.
    You have not provided any details regarding your exact problem. Have you tried wi-fi? Have you tried to connect via ethernet?
    For instance, if you struggle to connect via wi-fi, there could be a myriad of reasons that are essentially unrelated to the hardware of your Mac mini. Bad reception is an obvious cause for connection problems. Just because you may see a network in the list of detected networks, that does not mean you can necessarily connect to it. This is especially true if there is strong interference from other networks. (This is also an issue with other platforms and operating systems.)
  • »16.10.20 - 06:47
    discreetfx
    Yes, I’ve tried WiFi and Ethernet. MorphOS lists both in the network Prefs but they don’t work.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »16.10.20 - 12:22
    Samurai_Crow
    Bad news. Both of my spare Mac Minis are Intel models. The one that came with the PPC model was one of these: https://everymac.com/systems/apple/mac_mini/specs/mac-mini-core-2-duo-2.26-late-2009-specs.html and what tipped me off was the mini-display-port video.
  • »16.10.20 - 13:19
  • ASiegel
    @ discreetfx
    Would you mind uploading a screenshot of your network settings to Google Drive and share the link? It seems somewhat improbable that both the ethernet and wi-fi functionalities are broken at the same time.
    Perhaps there is a wrong setting enabled.
  • »16.10.20 - 14:57
    discreetfx
    Sure, I can do that.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »16.10.20 - 15:05
    discreetfx
    Here’s a couple of pics.
    https://ibb.co/1XxZWWz
    https://ibb.co/1dgDT8h
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »16.10.20 - 18:06
    Drako^lM
    Posts: 144 from 2005/8/10
    Test it also from clean instal ... or live cd for example
    Hardware :
    Power Mac G5 2.3 Ghz & MorphOS 3.18 & OSX 10.5
    Mini G4 1.5 Ghz & MorphOS 3.18
    BlaBla Team Member -> http://blabla.ppa.pl
    AmiParty Team Member -> http://www.chal.pl/
  • »16.10.20 - 18:10
    discreetfx
    This is a clean install.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »16.10.20 - 18:32
    Posts: 2065 from 2003/6/4
    As the WL0 is marked green it looks as if the mini had connected to your network. Have you looked into the connections on the router's interface. Seems to be rather a network error/misconfiguration.
    Have you checked this thread: https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=12977&forum=3
    Looks like a similar issue.
    [ Editiert durch Zylesea 16.10.2020 - 23:54 ]
  • »16.10.20 - 19:34
    discreetfx
    I’m replacing some network cables tomorrow to see if that’s the issue. That still wouldn’t explain why wireless didn’t work though unless that’s an experimental feature.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »17.10.20 - 21:14
    NewSense
    Posts: 1535 from 2012/11/9
    I can't say it's affected me specifically, but some users have mentioned in the past that selecting/using a specific channel, WiFi - Channel 6 may be best option for WiFi with MorphOS, that can make the difference between it working or not, so maybe that too could be an issue currently?
  • »17.10.20 - 22:02
    Posts: 79 from 2020/5/1
    NewSense: for 2.4 GHz wifi you should use channel 1, 6 or 11 to avoid overlapping channels. And use only 20 MHz (not 40 MHz) channel bandwidth.
  • »18.10.20 - 09:51
    discreetfx
    Issue solved and not MorphOS related. I'm not sure what ethernet gremlin was affecting my network but it went away when I replaced my two router/switches with one NetGear 24 port switch.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »19.10.20 - 23:40
    discreetfx
    What are the RAM requirements of Wayfarer? OWB launches fine but Wayfarer won't bring up any webpages. Snoopium shows it failing on every process it try's to open.
    Fixed, never-mind.
    [ Edited by discreetfx 19.10.2020 - 20:58 ]
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »19.10.20 - 23:47
