Posts: 545 from 2010/2/10
@IKE Have you 32 or 64Mb graphic video ?
Because i buy MacMini (64Mb) to test, i can tell 64Mb video is low....
If is the case, test with lower Ambient resolution and disable "Enhanced display" option.
For Example prBoom-plus crash quickly in opengl with MacMini and not with my other machine with 128/256Mb....
MilkyTracker switch window to fullscreen has same problem, so i think all port are affected.
@all
1. I prepare new release SDL 2.0.14 (unless hardware accelerated in first time).
I am waiting next release of MorphOS and if nothing is fix, i release Hardware accelerated in state because 90% of my port working with it, so i think so everyone can enjoy with it.
2. I discover a problem with installer in SDL2, neeed SDK to working correclty, i fix that on next version.
3. I could port FluidLite with BSzili (FluidSynth version lite), i implement it on ScummVM..
The result is very impressive in terms of MIDI sound!
