Posts: 1233 from 2010/1/6
Tested it again - is reproducable! And is seems that it does some deep things to system, because, even after a warm-reboot, there are some stange things, like Wordpad, MorphED, etc. loads textfiles correct (name shown in windowborder), but no text is invisible (or there is none)! After a cold-reboot everything works normal.
Think, this could be a issue of new Radeon-Driver.........
Will check that out to Peg2, Efika, Mini and PB, whether thy do the same.....
Workaround by setting monitor-blank-time to zero works, of course!
