Xorg on G5
    Posts: 12501 from 2003/5/22
    > ELFv2 BE ABI works fine on ppc64.
    Yes, I know. Void PPC successfully started it some years back, as comment #50 has been a testimony to.
    > I've been using it since v6.2 and never had any problems with it. Kernel also
    > gets a little bit smaller. As of v6.3 you can also build your BE kernel with
    > clang/lld (at least clang-15 is needed), which was not possible before.
    Yes, I took as much from your comment #70 and added the Clang info shortly after to comment #69 :-)
    > AFAIK it's only a ppc64-thing. 32bit ppc uses a different ABI anyhow.
    Yes both ELFv1 and ELFv2 ABI are PPC64-only (see comment #65). And yes, Linux/PPC32 uses SVR4 ABI (see comment #67).
  • »04.07.23 - 10:15
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    :-D Your memory of my postings is certainly better than mine.
    So the news value really only would be ELFv2 BE ABI going default for v6.5. Which is what you already posted. ;-)
  • »04.07.23 - 10:34
    ernsteiswuerfel
    Ok, then I'll try the new ISO. The beta one from July did not boot on my G5...
  • »15.09.23 - 18:47
    ernsteiswuerfel
    Andreas_Wolf schrieb:
    "we are planning to retire support for the big-endian 32-bit PowerPC and 64-bit POWER platforms."
    https://chimera-linux.org/news/2026/03/retiring-powerpc.html
    That is unfortunate, but was to be expected and for understandable reasons.
    And more or less the same outcome as for q66 previous project, Void Linux PPC.
    I think the reasons he cites are valid, but at least on mainline mesa the situation hopefully will improve, at least for the r300 driver as a very capable dev is willing to spend time on fixing BE issues (klick).
  • »20.03.26 - 20:41
