Xorg on G5
    ernsteiswuerfel
    Posts: 545 from 2015/6/18
    Thought this thread would be apt for posting this:
    A really nice overview of the working state of GPUs in current Linux.
  • »27.06.20 - 22:03
    wicknix
    Posts: 18 from 2020/12/1
    These will help remedy some of the browser issues (or lack thereof) on 32-bit ppc Linux. Generic G3 (no altivec) builds compatible with ubuntu, debian, fienix, mint, gentoo, and void (glibc version).
    Install via dpkg, or unpack the .deb and manually install to a location of your liking.
    Arctic Fox
    SpiderWeb
    Cheers
    [ Edited by wicknix 27.01.2021 - 17:45 ]
  • »28.01.21 - 00:42
    ernsteiswuerfel
    @Andreas_wolf: This is good news, thanks for the update!
    "A G4 ought to be enough for anybody." like Bill Gates once said. ;-)
  • »28.01.21 - 09:54
    Posts: 12085 from 2003/5/22
    If this is meant in relation to "ELFv2 BE ABI", then no. ELFv2 is strictly 64-bit (as is ELFv1, btw), so no G4. In terms of MorphOS-compatible machines, this means G5/PPC970 and QorIQ P5.
  • »28.01.21 - 11:41
    ernsteiswuerfel
    Hmm... I didn't realize this would be 64bit only. His 32bit LE efforts seem to be for the G4 though. Would also increase software compatibility I guess.
  • »28.01.21 - 12:28
    > I didn't realize this would be 64bit only. His 32bit LE efforts [...]
    64-bit big-endian ELFv2 ABI and 32-bit little-endian SVR4 ABI are two distinct efforts that happen to be initiated by the same developer. There's no overlap between them.
    > [...] seem to be for the G4 though.
    From p. 22 and 29:
    "- Works as a chroot on 64-bit kernel [...]
    - Easier emulation of 32-bit x86
    - Port LE Linux to G3s/G4s? :) [...]
    - For now, strictly POWER8+ though
    According to this, bare-metal port to PPC32 hardware may happen, but is not the primary objective. The point seems to be the simplification of 32-bit x86 emulation on PPC64LE hardware.
    On another note:
    "we're planning [...] allowing the little endian userlands to work on G3/G4 powermacs"
    https://www.talospace.com/2020/12/void-ppc-goes-little-endian-on-32-bit.html?showComment=1608436832788#c1276631954537967166
  • »28.01.21 - 18:14
    ernsteiswuerfel
    Been running ELFv2 BE ABI since 6.2-rc1 on my G5 11,2 and Talos II and it just works. :-) Kernel and module size is a bit smaller due to lower stack usage it seems.
    ELFv2 BE ABI 6.2 kernel is also possibla with clang with use of yet-to-be-mainlined patches (see https://github.com/ClangBuiltLinux/linux/issues/1761). Performance seems on par but with some Altivec regressions compared to GCC build.
  • »23.02.23 - 22:37
    ernsteiswuerfel
    @Andreas_Wolf: Did you try Chimera on a G5? I wonder how it performs compared to other ppc/ppc64 Linux Distros?
  • »27.06.23 - 13:13
    No. If I do, it will be with a less experimental state :-)
  • »29.06.23 - 16:48
    ernsteiswuerfel
    @Andreas_Wolf: ELFv2 BE ABI works fine on ppc64. I've been using it since v6.2 and never had any problems with it. Kernel also gets a little bit smaller. As of v6.3 you can also build your BE kernel with clang/lld (at least clang-15 is needed), which was not possible before.
    But AFAIK it's only a ppc64-thing. 32bit ppc uses a different ABI anyhow.
  • »04.07.23 - 11:35
    Yes, I know. Void PPC successfully started it some years back, as comment #50 has been a testimony to.
    Yes, I took as much from your comment #70 and added the Clang info shortly after to comment #69 :-)
    Yes both ELFv1 and ELFv2 ABI are PPC64-only (see comment #65). And yes, Linux/PPC32 uses SVR4 ABI (see comment #67).
  • »04.07.23 - 13:15
    ernsteiswuerfel
    :-D Your memory of my postings is certainly better than mine.
    So the news value really only would be ELFv2 BE ABI going default for v6.5. Which is what you already posted. ;-)
  • »04.07.23 - 13:34
    ernsteiswuerfel
    Ok, then I'll try the new ISO. The beta one from July did not boot on my G5...
  • »15.09.23 - 21:47
