LibreOffice
    >>> I can't wait to see what [...] Mark, Frank, and Michal come up with for our video subsystems.
    >> Is Michal available again?
    > Keri?
    I thought the 'Michal' you mentioned is the one called Kiero ;-)
    Misspelling due to an autocorrect function I missed. Sorry, I'll fix that. And yes, I know, you've mentioned it before.
  • »30.06.19 - 20:18
    Posts: 12407 from 2003/5/22
    > I'll fix that.
    Seems this didn't work so well ;-)
  • »01.07.19 - 17:33
    Intuition
    Posts: 1113 from 2013/5/24
    Jim wrote:
    polluks wrote:
    Jim schrieb:
    We've got a good base with our current OS, go 32 or 64 bit, adopt a little endian ISA, memory protection, better OpenGL and graphics support and we got a winning combination.
    Let's call it Haiku...
    Oh hell, no!
    Don't drag me back to BeOS again, please!
    Even AmigaOS stands a better chance at resurgence than that.
    Closing my more contentious points, again, I'm confident we have a clean OS.
    A couple of years in tRumps US is enough to make anyone a little pararoid. ;-)
    BeOS: Amiga done right. ;)
  • »02.07.19 - 08:56
    Addendum:
    > Interesting note:
    > "X5000s CPU is not compatible with any FreePascal program at the moment"
    > Is this only true for OS4 or also for MorphOS on X5000?
    "Why my Programs does not work on AmigaOS4 X5000? The problem is, that FreePascal itself does not know the X5000 CPU, and it seems to be not a normal PowerPC, but needs some special care. I heard something about special alignment problems. I don’t have a X5000, Charlie doesn’t have a X5000 and we do not know whats special about it to fix that issue. Besides, we both are not really using OS4, we both use [...] MorphOS [...]. [...] If you are interested in Pascal and Amiga(OS4) and want to help with the compiler doing a better job on X5000 [...] you can just do it, it’s open source, send us a patch."
    https://blog.alb42.de/2020/05/30/freepascal-and-x5000/
    I have a feeling this doesn't really answer the question, does it? ;-)
    But this does:
    "I'd like to fix Free Pascal's code generator to work properly on the X5000 on AmigaOS4. [...] My guess is that OS4's kernel doesn't provide a full compatibility with the standard 603/G3 instruction set via emulation, esp. when it comes to various FPU alignment restrictions. (MorphOS might also affected partly, but its kernel is more robust in this regard.)"
    https://twitter.com/chainq/status/1276276393610002433
    https://twitter.com/chainq/status/1276277113474220033
    Edit: Finally solved:
    "this issue, or at least the worst of it is now fixed in Free Pascal SVN trunk. As usual, the issue was solved with the help of a MorphOS Developer. They provided remote access to an X5000. [...] It was some optional optimization in some memory copy/fill routine, which only works on a subset of PowerPCs - primarily the ones shipped by Apple back then - as it assumes a certain cache line size. This optimization should have been disabled for OS4, but it wasn't. [...] Meanwhile, it was also uncovered, that FPC's PowerPC code generator doesn't really respect a set of FPU data access alignment restrictions, but these are normally hid by the OS via exception handling. These to be fixed soon."
    https://twitter.com/chainq/status/1286752510313668612
    https://twitter.com/chainq/status/1286926079027011584
    https://twitter.com/chainq/status/1286927164303200256
    [ Edited by Andreas_Wolf 18.09.2020 - 22:39 ]
  • »29.06.20 - 12:10
