A possible future for MorphOS
    KennyR wrote:
    > people trying to adopt PPC found it difficult to get support chips.
    ...except when adopting a PPC SoC :-)
    PPCs SoCs sucked. They were full of bugs (being mostly untested), hard to get a hold of in any quantity, horribly underpowered, incompatible with desktop PPC instructions, or all of the above. There's a reason everyone in embedded moved on from PPC to MIPs (then ARM) in the early 00s.
    > When it came to NB and SBs, generally it was a case of
    > a. capable b. available c. bug-free: pick any two.
    This was never true for southbridge chips.
    Sure it was. Even the VIA chip the Pegasos used was a buggy piece of shit. No bugs quite as fatal as Articia, but a lot erratas to be worked around. And certainly it was never high end.
    > to my understanding ARM desktop never really took off anyway.
    Funnily, it was the desktop where ARM started ;-)
    StrongARM maybe, but not ARM as we know it. And StrongARM CPUs, while interesting, provided no real advantage over Intel, AMD, and Motorola CPUs of the era. An Acorn Archimedes was really no faster than an Amiga 500.
    Actually, the only decent Southbridge components that worked well with PPC cups and Socs were from ULi and ATI. When then X1000 was announced it was no big surprise that it utilized an SB600. That component was well documented, fairly compatible with the ULi Southbridges used on Freescale's evaluation boards, and relatively big free.
    I've always favored ATI/AMD components and hope at least one of the systems supported by MorphOS NG is AMD based.
    I'd still like Power9 support, though. ;-)
  • »02.04.19 - 12:52
    Posts: 12080 from 2003/5/22
    >>>> of a. capable b. available c. bug-free: pick any two.
    >> [...] a lot erratas to be worked around. And certainly it was never high end.
    You are referring to a later time frame starting around 2005, when you'd connect a PCIe southbridge to a PCIe-based PPC SoC or to a PCIe northbridge. KennyR's and my debate was about the time around half a decade earlier when you'd connect a PCI southbridge (or a southbridge supporting a fast but proprietary connection plus PCI as legacy fallback) to a PCI(-X) northbridge. And as far as I can tell, the VIA southbridge has worked rather well on the Pegasos in PCI fallback mode.
  • »02.04.19 - 14:57
    MorphOSUser
    Posts: 44 from 2012/5/2
    I got such a throbbing headache reading pages of everyone trying to proof a point of the other and throwing terminology and technicalities and so forth...
    personally...that is just my opinion....
    I love MorphOS in it's current hardware choices. Apple PPC laptops and desktops and I wouldn't want it any other way. I prefer the resources taking to making it appealing for developers and easier for developers to develop applications and games for the MorphOS PPC current hardware than to invest in porting it into other hardwares and tugging back and forth which hardware is the best to go. I love my iBook G4 laptop...I love my MorphOS 3.11 and I want to write fresh apps for it.
    By the way...I am unsure what is the final conclusion? Where have we reached or is it an endless on-going discussion that no one will agree on?
    [ Edited by MorphOSUser 03.04.2019 - 07:48 ]
  • »03.04.19 - 07:48
    After the Apple PPC laptops and desktops, MorphOS has already been ported to other hardware: ACube Sam460 (AmigaOne 500) and A-Eon Cyrus Plus (AmigaOne X5000) :-)
    > what is the final conclusion? Where have we reached [...]?
    The MorphOS team's long-term plan to release a MorphOS "NG" on x86-64, as originally announced in 2011 and confirmed numerous times after that, is apparently still valid.
  • »03.04.19 - 11:04
    MorphOSUser
    Then conclusion is done! Discussion over!
    Unleesss you guys are just having fun and throwing opinions and having intellectual debate back and forth....trying to see who can outsmart the other with a convincing argument....if that is the case....have at it! - grin -
    Who am I to spoil the fun? ^___^*
    By the way, I start to compare MorphOS with Playstation O_O!
    Playstation 3 is backward compatible with PS 2 and PS1 (even if it is software emulated but done in such way you cannot tell if it is software emulated).
    MorphOS PPC is the same. It is backward compatible with 68k applications and even games as if it is native as long as the games are not banging hardware (done via software layer that the user cannot see or notice and feel like it is native)
    Playstation 4 is x86 and it is NOT BACKWARD compatible.
    MorphOS x86 IS NOT BACKWARD COMPATIBLE and will have it's own libraries separate from MorphOS PPC.
    To play old PPC MorphOS applications/games or 68k applications/games you need to keep your old system for backward compatibility and modern x86 system for new applications/games. This is true for Playstation as well.
    Can I say that this is hot?! O_O!
    If I want MorphOS x86 I have to pay for it (even though I paid for MorphOS PPC). WHICH BY THE WAY I AM 100% OK WITH THAT! Hehehe
    [ Edited by MorphOSUser 03.04.2019 - 15:18 ]
  • »03.04.19 - 15:05
    > Then conclusion is done! Discussion over! Unleesss you guys are just
    Hehe, yes, MorphZone is also for discussion. In this case, the thread opener opposed the MorphOS team's announced x86-64 plans and suggested moving to MIPS instead. The fact that the MorphOS team has decided for a certain strategy doesn't mean it can't be opposed/discussed and some alternative plan be suggested (and also discussed itself in turn, as expressly desired by the thread opener). Participation is voluntary, of course :-)
  • »03.04.19 - 15:25
    MorphOSUser
    Hehe....that is ok - rubs head - I stopped at page 3 and I couldn't read anymore - closes eyes tight - you guys throw huge words, complicated terminologies and it looks like it is going on and on and on and on and on and on with tug of war discussion back and forth! The debate is piling on top of each other ...- closes eyes tight - makes my head inflated and by all means not a dis at you guys at all. It just you guys are way too smart for me...so I erm...wanted to see if there is a conclusion and when I saw it continues at page 5 I was like..OKAY I aint going to read all that!!
    [ Edited by MorphOSUser 03.04.2019 - 15:36 ]
  • »03.04.19 - 15:35
    > I [...] wanted to see if there is a conclusion and when I saw it
    The original discussion of MIPS as a possible future for MorphOS stopped somewhere at the top of page 5. At that point, the thread opener was still retaining his stance while most (all?) others had been opposing it. So, the conclusion (if any) is more implicit than explicit and requires reading the thread to be arrived at, I'm afraid ;-)
  • »03.04.19 - 15:50
    ppcamiga1
    Posts: 215 from 2015/8/23
    future for MorphOS?
    Make MorphOS open source on LGPL license and let everyone use whatever they want
    [ Edited by ppcamiga1 03.04.2019 - 17:29 ]
  • »03.04.19 - 17:28
    jarokuczi
    Posts: 18 from 2016/12/6
    In the other hand, you can look at the Xbox.
    Xbox Classic was x68
    Xbox 360 was PPC and had backward compatibility with Classic
    Xbox One is amd64/x86 and it have backward compatibility to 360 and classic.
    unfortunately, to us, 360 was ppc64 le.
    [ Edited by jarokuczi 04.04.2019 - 09:45 ]
  • »04.04.19 - 08:40
    jarokuczi
    > 360 was ppc64 le.
    No, Xenon is big-endian PPC64 and includes big-endian PPC32 compatibility.
    https://en.wikipedia.org/wiki/Xenon_(processor)#Specifications
    You're right. I remember that I've been running Debian compiled for ppc64le on my 360, but it was couple years ago and I might be wrong.
  • »04.04.19 - 17:08
    I guess so, as Debian for little-endian PPC64 requires POWER8 or newer.
    https://wiki.debian.org/ppc64el#Required_Hardware
  • »04.04.19 - 18:01
    Posts: 22 from 2019/11/25
    Zylesea wrote:
    If MorphOS NG gets say 20.000 - 50.000 users it can easily sustain in a healthy tiny niche which operates way under the radar (which has some pretty advantages).
    [ Editiert durch Zylesea 10.03.2016 - 23:24 ]
    Being reading this post out of curiosity because I don't have MorphOS. I would like to, but I think the hefty 80 eur price tag is pretty absurd.
    I've post a thread on that, and I've almost been banned. They will never grow to 20k users, just because the dev team is greedy. Forget about healthy niches. I would even say that some guys from the dev team are pretty toxic (just read my topic).
    [ Edited by supremo 26.11.2019 - 01:09 ]
  • »26.11.19 - 02:09
    Britelite
    Posts: 66 from 2003/6/4
    Sure you're not just making things up?
  • »26.11.19 - 07:50
