OGR-28 graph updated and moved
    Krashan
    Posts: 1107 from 2003/6/11
    Another update, 25 September. The Czech team should be taken this weekend.
  • »25.09.15 - 17:47
    Krashan
    16-th place taken! 29 September.
    [ Edited by Krashan 29.09.2015 - 05:35 ]
  • »29.09.15 - 02:34
    tolkien
    Posts: 565 from 2013/5/29
    I have tried to join Morphos team but I have requested my password yesterday and don't receive It. :(
  • »29.09.15 - 03:09
    Posts: 1353 from 2004/2/8
    Beef Roast, we're coming for you!
  • »29.09.15 - 05:34
    Krashan
    Graph updated again, scale changed to accomodate our progress: 9 October 2015.
  • »09.10.15 - 14:54
    tolkien
    I can see there my 2950 fully gnodes! Hehehehe! Not much help but will keep doing when I can.
  • »09.10.15 - 16:36
    Doffo
    Posts: 508 from 2010/10/14
    Ever bit helps. Noticed one of my lazy r200 servers had the Dnet client closed. Fired it back up and everything is good again.
    YUUUP!
  • »09.10.15 - 17:06
    diezi7
    Posts: 167 from 2005/7/25
    I don't remember password or email used.
    Sent a mail to help@distributed.net looking
    for some help on joining the effort.
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »25.10.15 - 09:10
    Tom01
    Posts: 187 from 2009/9/20
    Search for your User-Name in Participiant-Stats and click "please e-mail me my password".
    If that does not work, you have to create a new Account.
  • »25.10.15 - 13:28
    diezi7
    Thanks Tom01, just tried that several ocasions without any result.
    But I don't know/remember nor find how to create a new account.
  • »25.10.15 - 13:41
    tolkien
    You create when you install the dnet client. Insert the email you want to use. Then, as Tom01 says, request the password for that email.
    You can only request a password once you have upload at least one node.
    I requested my password but finally had to write a mail cos I hadn't received It.
    Good luck Victor!
  • »26.10.15 - 08:21
    diezi7
    Good luck Victor!
    Thanks Loco !!
    I'll try that way too ;-D
  • »26.10.15 - 17:12
    Krashan
    Graph for 31 October. It is expected that we will move one place up tomorrow, or on Monday.
  • »31.10.15 - 15:39
    tolkien
    Sure! We're very near. Let's do more nodes!
  • »31.10.15 - 17:29
    _ThEcRoW
    Posts: 298 from 2008/10/27
    But, what's the point in naming the group amiga if the majority of raw power comes from machines that have nothing to do with it?
  • »01.11.15 - 15:12
    Doffo
    True. Same could be said about Team MorphOS. Suppose we could use a ton of PPC hardware to try to crunch away, but by the time a stack of MorphOS machines crunch a certain chunk, one of my dell servers can do that amount of work easily.
    We just play favorites and crunch away! :)
    YUUUP!
  • »01.11.15 - 21:34
    tolkien
    Well, there are a lost of differents teams and lot of them are not computer related. One is about beer and I don't think beer can crunch data! ;)
  • »01.11.15 - 21:54
    Posts: 12528 from 2003/5/22
    Indeed. That's why the more interesting statistics is this:
    http://stats.distributed.net/misc/platformlist.php?project_id=28&view=tco
  • »01.11.15 - 22:02
    Krashan
    So we are on 15-th place now, and the next one is in our direct range. Also "SEGA Users Group" does not look like a hard nut to crack in a month or so. Then, there is "Distrubuted Amiga"... ;-)
    [ Edited by Krashan 02.11.2015 - 08:15 ]
  • »02.11.15 - 05:14
    tolkien
    Distributed Amiga is a very difficult target cause they process the same nodes as MorphOS team. We are a bit stronger so let's do It.
  • »02.11.15 - 06:10
    No they don't. They do at least 100k gnodes/day less than we do. It'll take a while though to pass them. Alas, we have all the time in the world for that (11% done by far).
  • »02.11.15 - 07:25
