Posts: 2053 from 2003/6/4
TheMagicM schrieb:
I'll look into it. I wouldnt mind something thats portable which can also run on Linux with some editing etc.
Keeping the code compatible for compiling Linux or Windows versions is not free of little traps but rather easy. Sure, if you use MUI for your MorphOS version, then quite some changes are required to make a Linux or Windows version. That's the reason I haven't used MUI much yet with Hollywood, but for my latest project I will probably use a MUI GUI for MorphOS.
