complaint when starting OSX (Dual OS)
    TomKeric
    Posts: 146 from 2013/2/18
    I have OSX next to MorphOS
    (Just installed the OSX) when startup I get a complaint
    DISK REPAIR
    The disk "Boot" was not repairable by this computer
    It is being made available to you with limited functionality. You must back up your data and reformat the disk as soon as possible.
    WHAT THE HECK! Dont touch my MorhpOS boot disk that I created with blood sweat and tears :)
    Any idea why this message is shown and if it is possible to turn it off in OSX.
    -If you've never failed, you've never tried -
  • »28.03.13 - 13:46
    stephen_robinson
    Posts: 746 from 2007/4/22
    I think I fixed this by simply copying the files off formating it in MacOS copy them back on, and now no complaints.
    At least I think that was what I did.. can't quite remember now..
  • »28.03.13 - 16:42
    Posts: 3311 from 2003/3/5
    You can format the partition and copy files allright, but you have to remember you won't be able to boot automatically without blessing the file again by using hfssetmacboot boot:bootinfo.txt - you'll have to boot manually from OF or from a boot CD to fix this.
  • »28.03.13 - 17:07
