Spambots on MZ
    MarK
    Posts: 641 from 2004/1/25
    Hi there,
    isn't there a way to add some checking to take care of spambots? These messages are pretty annoying...
    Bye, MarK.
  • »05.03.13 - 09:27
    hooligan
    Posts: 1948 from 2003/2/23
    I have tried to keep things clean and once again deleted a few threads. The problem is I STILL can't delete accounts or even delete all messages due to bugs in removal code.
  • »05.03.13 - 10:38
    Posts: 1075 from 2004/9/23
    Stupid idea, but is it possible to just edit the data like EMail and Password? Both together should disable them, too and using some unique email would help to find it later on.
    Geit
  • »05.03.13 - 15:43
    hooligan
    I have restrictions to both edit and delete accounts so at least I can't do it
  • »05.03.13 - 16:18
    _bigdan_
    Posts: 70 from 2009/1/7
    Never delete an account. Just disable it and if needed edit the profile to remove url or change password !
    bigdan
    (part of Amigaimpact.org staff)
  • »05.03.13 - 17:09
    MarK
    i saw a simple spambot defender, to add a message You have to write some special text... like: opposite of white. and if You write black, it works on, if no... cYa... :) simple, but effective against spambots.
    bye, MarK.
  • »06.03.13 - 18:15
    hooligan
    More bugs. Deleted spambots message and the whole thread disappeared. It was the one about interviewing JacaDcaps, very sorry for this inconvenience.
  • »07.03.13 - 08:30
  • ASiegel
    Posts: 1396 from 2003/2/15
    The discussion thread in question has been recreated.
  • »07.03.13 - 18:16
    Posts: 12498 from 2003/5/22
    ...bar the initial posting containing the actual interview.
    http://webcache.googleusercontent.com/search?q=cache:ovuR-yMKnKkJ:morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9041&forum=3
    Edit: Meanwhile, the Google cache has been updated to a point in time after the interview has been deleted from MorphZone. It is still to be found there:
    http://www.meta-morphos.org/article.php?sid=1482
    http://www.amiga.org/forums/showpost.php?p=725111
    http://morphosnordic.se/index.php?topic=97.msg515#msg515
    [ Edited by Andreas_Wolf 23.03.2013 - 10:31 ]
  • »08.03.13 - 14:28
    Posts: 1350 from 2004/2/8
    Sh!t, add a captcha to registration ASAP or else repeated spambot attacks will render this forum useless.
  • »17.03.13 - 05:35
    Rats
    Posts: 33 from 2013/1/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9083&forum=10 spambot heavy topic
  • »22.03.13 - 19:45
    stephen_robinson
    Posts: 746 from 2007/4/22
    Not as bad at this one:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8882&forum=32&start=100
     :-o
  • »22.03.13 - 21:01
  • ASiegel
    Thanks for pointing it out.
  • »23.03.13 - 00:51
