Dual boot problem (Ubuntu for partitioning)
    TomKeric
    Posts: 146 from 2013/2/18
    I followed the excellent guide on the library page on how to keep an existing OSX installation. (Have no DVD)
    The guide says to use Ubuntu to partition/ slice the disk. But Ubuntu 9.4 does not recognize the file format of the existing partition. (should be HFS+) but it is unkown and therefor cannot slice the disk.
    Tried to install some alternative Ubuntu PPC versions - but I couldn't get any of them to launch on live CD.
    I use a MacMini 1.5. Anyone knows a working Ubuntu version or any other solution on how to slice up the disk without destroying the OSX installation. I plan to leave some 20-25GB for OSX and the rest for MorphOS.
    Help is appriciated. First one helping me is declared AWESOME :-)
    -If you've never failed, you've never tried -
  • »13.03.13 - 14:47
    Posts: 2581 from 2003/2/24
    Can also be done by booting from OS10.5 (Leopard) DVD.
  • »13.03.13 - 15:06
    Leif
    Posts: 111 from 2006/5/31
    I recently used http://torvi.atm.tut.fi/ubuntu-dvd/12.04/release/ubuntu-12.04-desktop-powerpc.iso to partition for dual booting with MorphOS. I remember some bits
    of the GUI in Gparted was a bit different from the dual boot guide
    (I think some alignment gadget was named differently) but it all worked
    well in the end.
    [ Edited by Leif 13.03.2013 - 21:17 ]
  • »13.03.13 - 18:15
    TomKeric
    Hmm. I dont have any OSX dvd so that is a dead end.
    I actually downloaded 12.04, but the live CD booting failed on my mac mini. Ended up with various hardware complaints in ubuntu and a freezed black image with ubuntu tech talk.
    Ubuntu 9.4 booted all the way, but as said initially the file format cannot be recognized in the partition editor.....
     :-( puzzled on what to do here....
  • »13.03.13 - 20:00
    TomKeric
    I took away the journal type in terminal of OSX. This made HFS+ visable in Ubuntu Gparted, but sadly it was still not possible to resize, it seems locked where it is. :-(
  • »14.03.13 - 18:48
    ausPPC
    Posts: 543 from 2007/8/6
    The better solution would be to get an OS X dvd - where's your nearest linux club? A somewhat extreme option is to get an external 2.5" IDE to firewire enclosure for your mini's current internal drive and replace the internal drive with a new one for other OSes. Maybe you could get an IDE SSD while you're at it.
  • »14.03.13 - 19:57
