Installing SDK
    Tomo
    Posts: 92 from 2003/7/29
    I tried to install last SDK-package (Grunch) but I got the mesage: installation failed. Filetype is unknown.
    Am I missing a library or command or ......?
    Regards Tom
  • »06.02.13 - 12:49
    Posts: 186 from 2003/10/23
    the fastest choice to install the SDK is to download it from here:http://www.morphos-team.net/downloads
    double click to view the content of the lha and double click to launch the installer :D
    I'm nerdy in the extreme
    And whiter than sour cream
    White&Nerdy 2006 Al Yankovic
  • »06.02.13 - 15:24
    Tomo
    de-archiving is not the problem. It becomes a problem when I start the installer. After 2 seconds I get the message of the unknown filetype.
    I tried Snoopiium but that gives me no clue.
    regards Tom
  • »06.02.13 - 15:38
    Posts: 1075 from 2004/9/23
    Did you install stuff like the ultimate pack? It may overwrite/override filetypes.
    Geit
  • »06.02.13 - 21:24
    Tomo
    @ Geit
    no, and there was never a problem with installing the SDK before.
    As far as I know I didn't install something weird but I will check C and Library in MOSSYS and the Filetypes
    Regards Tom
  • »07.02.13 - 08:05
    Posts: 3275 from 2003/3/5
    That could suggest a problem with xad's tar or xz plugins.
  • »10.02.13 - 16:14
    Tomo
    So, after all I did something weird somewhere. The xpk.master was missing....
    Thanks for the tip
    regards Tom
  • »10.02.13 - 21:33
