rc5072 moo!
    bash64
    Posts: 972 from 2010/10/28
    Sorry to post this but I cannot find the article that tells you how to get rid of that awefull Moo! thing that keeps popping up.
    Is this a friggin virus or what?
  • »20.01.13 - 21:08
    stephen_robinson
    Posts: 746 from 2007/4/22
    Moo bunny?
    I'm afraid there's no solution to that.
    I've no idea about what other moo! thing you're talking about.
  • »20.01.13 - 21:13
    Posts: 2079 from 2003/6/4
    bash64,
    I'm not sure what you mean (I don't have an "awfully Moo thing" on my machines), but I remember some "trojan" by Tokai to support dnet crunching and his favour for cows. Maybe this old thread is of help:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=3039&viewmode=flat&sortorder=0&start=0
  • »20.01.13 - 21:27
    boot_wb
    Posts: 874 from 2007/4/9
    Tokai's little cutie!
    Try installing this library in place of the one installed in your libs, as suggested by Andreas_Wolf.
    Incidentally, if you're running dnetc that could explain your Powerbook getting hot (although not the failure to shut down).
    @Papiosaur
    Might be worth updating the get9.library in pack ultimate (the one that's used by snes9xstarter, which if downloaded from the url in the readme includes this little 'trojan princess').
    EDIT: Damn, Zylesea beat me to it!
    [ Edited by boot_wb 20.01.2013 - 23:33 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »20.01.13 - 21:31
    bash64
    Thats when this damn thing first came up, I decoded to try out the snes emualtor on the powerbook.
    Now I can't get rid of this dumb moo message on boot.
  • »20.01.13 - 21:51
    bash64
    get9 dummy library worked.
    I'd like to know where it plugs itself in so that it runs on boot?
    I checked tasks for a dnet but didn't see anything.
  • »20.01.13 - 23:34
    Posts: 12498 from 2003/5/22
    Check the initial posting of the thread Zylesea linked to.
  • »21.01.13 - 06:16
    bash64
    That get9.library, do you know if it is required to run snes?
  • »21.01.13 - 20:44
    I'd suggest you simply try it without and see for yourself :-)
  • »21.01.13 - 21:05
