Powerbook and 3.x
    rebraist
    Posts: 96 from 2011/4/6
    I'm looking around for a g4 powerbook to use with 3.x.
    The main reason i'd buy one is wifi support.
    Is there any plan it will be done? (maybe there's now and i don't know it)
    Or should i continue with my mac mini?
    Thx!!
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »13.01.13 - 17:02
    Posts: 12570 from 2003/5/22
    > The main reason i'd buy one is wifi support. Is there any plan it will be done?
    ...via PCMCIA: yes (said to come with MorphOS 3.2)
    ...via AirPort Extreme: no (at least not in the short term)
  • »13.01.13 - 17:26
    rebraist
    thank you!
    i'll wait for the pcmcia wifi support then!
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »13.01.13 - 18:38
    Posts: 2095 from 2003/6/4
    As workaround I can recommend the TP TL-WR702N. Really tiny, very cheap (15-20 EUR), good antenna, works ootb and is poweed by a single usb port.
  • »13.01.13 - 19:08
    CountRaven
    Posts: 566 from 2007/12/10
    Can someone remind please, which PCMCIA card will be supported?
  • »13.01.13 - 20:18
    boot_wb
    Posts: 874 from 2007/4/9
    I missed that little gem of information, when was that announced?
    /me digs out Netgear WPN511 and crosses fingers that it will be supported.
    [ Edited by boot_wb 13.01.2013 - 22:22 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »13.01.13 - 20:22
    I think that there was no announcement made as such. But it was told by MorphOS Team members during the last months that the only thing still missing was the configuration GUI and that they were diligently working to complete that. That's why I (and others) assume that it will come with MorphOS 3.2.
  • »13.01.13 - 21:15
    Follow the link to find what was said on the roadmap regarding the chipset type back then:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=6042&start=102
  • »13.01.13 - 21:34
    boot_wb
    @Andreas_Wolf
    I do hope so.
    The inclusion of os-include/devices/sana2wireless.h in the SDK may also support that assumption. :-)
  • »13.01.13 - 21:47
    Posts: 2220 from 2003/2/24
    boot_wb,
    With a very quick googling and checking only the first page, it looks to have chipset based on Atheros 5000 serie, so I'd guess it should work or at least you could hope it'll work :)
  • »14.01.13 - 04:54
    Crumb
    Posts: 738 from 2003/2/24
    I wonder if Prism2 will work too as I have a pair of cards from my A600/A1200 that could serve me well.
  • »14.01.13 - 12:22
    boot_wb
    @JPV
    I did buy it for the chipset, but with it having a Super-G (108Mbps) mode I'm not 100% sure. My router is also Netgear with Super-G, so am crossing my fingers twice on this one (ouch). :-)
  • »14.01.13 - 12:26
    Interesting comment on Prism2 support:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8987&forum=11&start=8
    I don't know if that would also involve PCMCIA cards or if it would be restricted to PCI cards, though.
  • »15.01.13 - 21:40
