Posts: 680 from 2009/10/20
Trouble shooting with reports from logtool.
the firewire external logs in fine but the last line of the report?
PHY packet received, data=$00040500
PHY packet received, data=$000c0500
[INF][HC_SBP2-sbp2_login : 926] LOGIN: succeed!
[INF][HC_SBP2-sbp2_login : 927] LOGIN: Length : 16
[INF][HC_SBP2-sbp2_login : 928] LOGIN: LoginID : $0
[INF][HC_SBP2-sbp2_login : 929] LOGIN: CommandAgent : $FFC1FFFFF0100000
[INF][HC_SBP2-sbp2_login : 930] LOGIN: ReconnectHold : $3
[INF][HC_SBP2-sbp2_do_write_quadlet : 362] Write quadlet $000c800f, @ offset $0000FFFFF0000210
[INF][HC_SBP2-sbp2_login : 944] New BUSY_TIMEOUT=$0000000f
[INF][HC_SBP2-sbp2_inquiry :1066] do SCSI_INQUIRY, pass 1/3, data=0x261be17c
[INF][HC_SBP2-sbp2_inquiry :1104] INQUIRY: done, 35 bytes
RptMsg: [SBP2] Unit #0: Vendor: Hitachi, Product: HDS721616PLAT80, Version: P22O
[INF][HC_SBP2-sbp2_inquiry :1122] INQUIRY: device type = $0e
[INF][HC_SBP2-sbp2_inquiry :1145] INQUIRY: removable support: no
[INF][HC_SBP2-sbp2_get_capacity :1200] Send SCSI_DA_READ_CAPACITY
[INF][HC_SBP2-sbp2_get_capacity :1222] GEOMETRY: SectorSize: 512, TotalSectors: 321672960
[INF][HC_SBP2-devQuery : 471] SBP2 unit @ 0x289dcd88
[INF][HC_SBP2-devQuery : 477] QUERYINFOATTR_DEVICE_UNIT_UNIT 0
[INF][HC_SBP2-devQuery : 457] QUERYINFOATTR_DEVICE_MASK $fffffffe
[INF][HC_SBP2-devQuery : 463] QUERYINFOATTR_DEVICE_MAXTRANSFER $001fffff
[INF][HC_SBP2-devQuery : 483] QUERYINFOATTR_DEVICE_UNIT_LUN 0
[ERR] SBP2 > Not supported IO cmd: 29
It logs in fine but what does "[ERR] SBP2 > Not supported IO cmd: 29" mean?
Osco
[ Edited by osco 31.12.2012 - 06:12 ]Mac Mini 1.5GHz, 1G, 250G Drive, Apple Cinema Display, MorphOS 3.1 registered, MacOS 10 PowerBook (5,8) 1.67Hz, 2G, 80G Drive,........Waiting
