Is WbRun a standard command?
    ChrisH
    Posts: 167 from 2009/11/26
    Just a quick question:
    Does the WbRun shell command come with MorphOS as standard? (I think it does, but I want to be sure.)
    [ Edited by ChrisH 21.12.2012 - 12:36 ]
  • »21.12.12 - 10:33
    Posts: 1520 from 2003/2/24
    Yes WBRun is included as a standard.
    http://library.morph.zone/Shell_Commands
  • »21.12.12 - 11:19
