MorphOS, OS4, and Linux on same machine?
  • phx
    phx
    Posts: 70 from 2005/3/29
    I just wanted to mention that NetBSD/ofppc also works fine on the Pegasos2 and supports all available devices, including Firewire and Gigabit ethernet.
    And unlike Linux or other BSDs we won't abandon Pegasos support. I can guarantee it, because I am the author of the port. ;-)
    I'm running three operating systems on my Peg2 (MorphOS/OS4/NetBSD).
    If you want to try it, download a recent snapshot from nyftp.netbsd.org. The last release (5.1) is old and doesn't boot from Amiga RDB partitions.
  • »29.11.11 - 18:37
    Henes
    Posts: 507 from 2003/6/14
    @phx
    Have you tested it on a partition located beyond or crossing the 1TB boundary?
    Linux's RDB support is broken there.
  • »29.11.11 - 19:28
  • phx
    phx
    Good question. I have no disk larger than 500GB, so I never tried it. The RDB support code is nearly identical to NetBSD/amiga.
    When looking at the source there might be a problem with partitions larger than 2TB or starting after a 2TB boundary. This needs to be checked. Thanks.
  • »30.11.11 - 07:00
    CountRaven
    Posts: 566 from 2007/12/10
    IS there support for the Pegasos 1 board?
  • »30.11.11 - 07:43
  • phx
    phx
    I'm quite sure the kernel would support Pegasos 1. The problem is booting it.
    The OpenFirmware implementation on the Peg1 is badly broken. I can neither boot from network nor from an installation CD using the OFW-seek and read methods. I even had a tester who tried to boot from an MSDOS partition.
    I would need a Pegasos1 myself to find a workaound.
    [ Edited by phx 30.11.2011 - 17:45 ]
  • »30.11.11 - 15:42
    Posts: 12570 from 2003/5/22
    > AFAIK the only Linux distributions that should have out of the box Pegasos II
    > support in their most recent versions are Debian, Gentoo and Crux.
    Now maybe openSUSE as well:
    http://www.powerdeveloper.org/forums/viewtopic.php?p=16751#p16751
  • »25.10.12 - 21:20
