License Key Questions
  • fmh
    fmh
    Posts: 75 from 2012/8/23
    I haven't purchased a key yet. Partially because I haven't decided where I want Morphos to live yet. I have a couple of G4 Macs available. Currently I have it on my G4-500DP which is my lowest powered G4 but Morpos 3.1 runs fine on that machine.
    I understand the process of purchasing a key and transferring it if the computer dies. But what happens if you format the drive and install Morphos fresh? Do I just type in the Key Code and life goes on? Reason I ask is that in the 6 weeks I've been messing with Morphos I have installed it fresh three times.
    G5 2.0DP, MorphOS3.13
  • »09.10.12 - 15:29
    pampers
    Posts: 1068 from 2009/2/26
    Just keep the key at some safe place (I use gmail for example) and after new install just drop it to DEVS:
    MorphOS 3.x
  • »09.10.12 - 15:44
    Posts: 2564 from 2003/2/24
    The key is a small file which is sent to you via EMail goes into sys:devs.
    Just keep a copy of that file in a save place and replace whenever you do a reinstall.
    With your PMac it might be a good idea to search for a better single CPU module,
    even the stock one from a QuickSilver (733 to 933MHz ) would give you big boost.
  • »09.10.12 - 15:46
    caver99
    Posts: 131 from 2012/6/14
    I have just regestered my second machine, first is a powermac g4 quicksiver 2002 dual 1gb and now a powerbook 5,8, i am lovin MOS now.
    Powermac quicksilver Dual 1ghz Dual Boot Morph OS 3.7 and OS X 10.5.8
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »09.10.12 - 17:44
    Posts: 1354 from 2004/2/8
    Could you please give us your reg number and the exact date of registration so that I could add it to the graph?
  • »10.10.12 - 12:49
    caver99
    Hi koszer, i will check my e-mails later and machines and send you the info.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »11.10.12 - 05:34
    caver99
    ok where do i find out what my reg number is?
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »15.10.12 - 13:11
    redrumloa
    Posts: 1424 from 2003/4/13
    caver99,
    Look at the first registration email reply, there will be a link you clicked on somthieng like this:
    http://registrations.morphos-team.net:80/payment/XXXX(plus much more yadda yadda yadda)
    Where XXXX would be the license number.
    [ Edited by redrumloa 15.10.2012 - 11:03 ]
  • »15.10.12 - 14:01
    caver99
    Ah ok will check and post in a bit
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »15.10.12 - 14:26
    caver99
    My Powermac G4 Qucksilver 2002 Dual 1GB says 1452 - 14/06/2012 18:51
    My powerbook G4 one says 1629 - 09/10/2012 20:31
    Hope this help to the graph.
    Graham
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »15.10.12 - 16:32
