Convert IMG CD image to ISO under MorphOS?
    redrumloa
    Posts: 1424 from 2003/4/13
    As the title says. I have a IMG CD image I want converted to ISO so I may mount under morphOS.
  • »23.09.12 - 23:27
    Posts: 3336 from 2003/3/5
    Did you try renaming it? :)
  • »23.09.12 - 23:53
    redrumloa
    jacadcaps,
    [quote] Did you try renaming it? :)/quote]
    No good, mounts but opens empty. Thanks for the thought...
  • »24.09.12 - 00:34
    Posts: 12570 from 2003/5/22
    You could try one of those:
    http://aminet.net/search?name=2iso&path[]=disk/misc&path[]=util/misc&path[]=disk/cdrom&arch[]=m68k-amigaos&arch[]=ppc-morphos
  • »24.09.12 - 05:27
    Jambalah
    Posts: 820 from 2008/3/30
    Hi Red! Try Iso-o-matic:
    http://aminet.net/package/util/conv/iso-o-matic-os3
    It works flawless but you will need ClassAct... uhu.. Maybe that sounds a little bit heretic?!? :-P
    The following input formats are supported:
    - b5i
    - bin
    - c2d
    - cdi
    - cso (Compressed ISO)
    - daa
    - dax
    - dmg
    - gi (?)
    - img (CloneCD)
    - iso
    - mdf (Alcohol)
    - nrg (Nero)
    - pdi
    - raw
    - toast (same as iso)
    - uif
    and output are -iso and -cso (compressed iso). If you don't have Workbench 3.x you can download ClassAct here:
    http://aminet.net/package/dev/gui/classact33
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »25.09.12 - 11:46
    redrumloa
    @Jambalah
    Looks good! I'll give it a shot when I get home  :-)
  • »25.09.12 - 12:51
    connor
    Posts: 650 from 2007/7/29
    I had the same task yesterday. http://aminet.net/package/disk/misc/ccd2iso worked fine for me.
  • »25.09.12 - 15:33
    redrumloa
    @Jambalah
    Slam dunk! Man, thank you! That is a great utility and exactly what I was looking for! I can live with Classact if the utility works that good!
    [ Edited by redrumloa 25.09.2012 - 20:47 ]
  • »25.09.12 - 23:45
