Radeon
    zbysiuk
    Posts: 59 from 2006/8/4
    I have a simple question, if is it possible to use Radeon 9600-9800 AGP from G5 in PM G4?
    I consider buying such a card and I would like to know which one is suitable for Morphos. I know R300 has only 2D drivers but is faster and offers more memory.
  • »10.09.12 - 09:39
    Posts: 3311 from 2003/3/5
    Are you sure it's not an AGP Pro card? Really hard to say if it's going to work when you don't mention the exact G5 and card model. A photo of the card could help too.
  • »10.09.12 - 11:29
    I've seen a 9600s modified to work. ADC connectors (if present) won't work.
    Some Apple 9800s work in both G4s and G5s, others only in G5s.
    Its much easier to re-flash a PC 9800.
  • »10.09.12 - 12:40
    Jim is using a 9800XT in his G4 PowerMac, so he is the guy you should listen to regarding which one to buy for your MorphOS G4 PowerMac use.
  • »10.09.12 - 15:17
    Well I'm no expert, but I am running a PC XT with an original Apple BIOS to maximise the speed.
    If you want DVI output, you need to flash a 9800XT with a 9800Pro BIOS file (runs slower, but both VGA and DVI outputs work).
    I have to us the VGA output of my card.
    And I don't know about original Apple 9600s, but I avoid re-flashed PC 9600s as their video output frequently is sub-par.
  • »10.09.12 - 15:57
    zbysiuk
    That is my favorite one:
    http://www.ebay.ie/itm/ATI-RADEON-9800-128MB-Graphics-Card-Mac-G4-and-G5-Systems-128-MB-/300776898460?pt=PCC_Video_TV_Cards&hash=item4607b33f9c
    or this one:
    http://www.ebay.ie/itm/ATI-RADEON-9800XT-256MB-Graphics-Card-Mac-G4-and-G5-Systems-256-MB-9800-XT-/300776900999?pt=PCC_Video_TV_Cards&hash=item4607b34987
  • »11.09.12 - 13:25
    redrumloa
    Posts: 1424 from 2003/4/13
    zbysiuk,
    Which G4? I found out the hard way that the Quicksilver 2002 has some specific issues with specific cards.
  • »11.09.12 - 14:57
    zbysiuk
    I try to find something for my PM G4 1.42 DP (FW 800). According to the hardware compatibility list, ATI Radeon 9600 Pro, 9600XT and 9800 ought to work properly but I guess are plenty of exceptions, that is why I want to determine which one is good, so is it some general rule to find the proper one?
  • »11.09.12 - 15:25
    pampers
    Posts: 1068 from 2009/2/26
    As I said to you recently just ask seller for a picture of working card in machine you are interested in, don't believe that cards are tested.
    MorphOS 3.x
  • »11.09.12 - 15:51
