Posts: 2727 from 2003/2/24
From the horse's mouth!
I think there are some variations of the Kabel family though, so pay attention and compare to existing artwork...
ITC Kabel is nice, the top/height of the lowercase letters are higher than the standard one. I used
ITC Kabel Std Book for smaller images, and
ITC Kabel Std Medium for little bigger graphics. Maybe not officially correct, I don't know, but it looked good to me!
You will find them all (and lots of others) in
Adobe Font Folio, which is easily found at you favorite downloading bay, I just checked, it's there...
[ Edited by takemehomegrandma 10.09.2012 - 01:20 ]MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
