best writing speed for morphos 3.1iso image?
    flea
    Posts: 17 from 2012/9/1
    Hi all.
    thanks to the moderators/owners of the site for welcoming me on here!!!
    i have gone and got myself a powerbook g4, 17" 1.67ghz with 2gb of ram, it was an absolute bargain! And in very good condition too.
    I now feel ready to take the plunge and put morphos on this machine...
    And i am asking the best burning speed for the cdrom blank disc. is it the slower the better (4x)???
    Once it has been burnt sucessfully, can i then just explore the morphos disk, before i copy it to the harddrive on the g4?
    kind regards Lee...:-D
  • »01.09.12 - 13:48
    Posts: 3311 from 2003/3/5
    Many PowerBook drives show problems with CD-R media, so I'd just recommend that you burn the iso on a DVD-R.
    You can boot the ISO and use a full system without installing.
  • »01.09.12 - 14:23
    boot_wb
    Posts: 874 from 2007/4/9
    Hi Flea,
    Welcome to Morphzone!
    The MorphOS .iso should burn ok at any speed, but slower burning may help to minimise any errors from poor media or faulty hardware.
    You should run the wizard to install rather than copying the contents of the CD across to your hard drive.
    Booting the Powerbook from CD will boot into MorphOS itself (and open a welcome screen from where you can choose to run iWizard to install MorphOS to your hard drive), although it's a fairly basic environment before you flesh it out with applications etc.
    Also, any changes to settings, network configuration etc will not survive a reboot until you've installed the OS to hard-drive.
    Regards
    Rich
    EDIT: Jacadcaps types faster.. :-)
    [ Edited by boot_wb 01.09.2012 - 16:31 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »01.09.12 - 14:30
    flea
    Hi jacadcaps!
    thanks for the quick reply...
    i have both types of media here, so i'll take your advice and use a dvd-r!
    cheers Lee. right then here i go!
  • »01.09.12 - 14:33
    flea
    ok cheers boot_wb!
    will follow instructions to the letter...
    thanks Lee
  • »01.09.12 - 14:36
    flea
    ok, so far so good!
    don't know whether to explore the cd or install to harddisk???
    flamin cars empty your wallet! and i just had a blue screen of death on this windows machine!!! weird.
    oh well, time to explore the cd on the power
    book, the floating butterflies screensaver has just come on the g4 laptop! ahhh aint that pretty... :-D
    cheers Lee
  • »01.09.12 - 15:26
    flea
    wow! it's very very fast...
    i'm using it now on the powerbook! the trackpad on the machine is a bit skittish, it actually prefers my left middle finger, rather than the right. But so far i'm very impressed with how sharp and speedy it really is...
    looks like i'll be registering it soon!!!
    cheers Lee. :-D
  • »02.09.12 - 12:32
    flea,
    cheers Lee.
    That's generally how people come to this community.
    "Wow!" and "I think I'll buy this. Its cool."
  • »02.09.12 - 16:16
