Posts: 2095 from 2003/6/4
> the hdd model listed by unit control is a Hitachi HTS54108. And that one is
> listed as a SATA drive.
Where? According to Hitachi GST, there are two models of the HTS54108:
- HTS541080G9AT00, which is PATA
- HTS541080G9SA00, which is SATA
http://www.hitachigst.com/hdd/support/5k100/5k100.htm
> Generally I thought and think G4 minis have a PATA interface
That't correct.
> but why does unit control report me the serial of a SATA drive
I think it doesn't. You have the PATA model, I bet.
You're right. I was just using the "HTS54108"-string for a google search and the first results showed the SATA version only. Hadn't thought of the option that the same series could be available in PATA and SATA. Maybe my short thought was supported by this surprising good data transfer rate.
Anyway, while not knowing the cause for this high number I am just glad the hdd performance is that brilliant.
