Installation script
    Cool_amigaN
    Posts: 772 from 2011/11/30
    Well, topic says it all.. I have created an lha that contains all the necessary files to apply as an Odyssey addon pack (for personal use) regarding spell checking (rather copying - paste individually files after each format) . I want to ,make an install script that will create some dirs, extract then copy files and open a .jpg at the end of it.
    How do I do? Is there any tutorial to study? I am using INO setup on Windows (GUI / script setup utility) and from what I know OS4 open bounty has an unassigned bounty for a similar type of program. Is there anything like that in Morphos, in general?
    Thanks for your time :)
  • »28.07.12 - 16:26
    Posts: 1520 from 2003/2/24
    Use Installer.
    You only need developer material from this package. The Installer application is included with MorphOS by default (C:Installer).
  • »28.07.12 - 16:30
