SMBFS reading wrong file sizes.
    matt3
    Posts: 785 from 2004/2/10
    I have a few 5 gigabyte movie files on a windows xp pro system with ntfs. The files only show between 1.4 and 2 gigs. If I copy them over to my icefs partition they are truncated with the smaller size. I read the files and they are turncated, the movies stop a 1/3 of the way through.
    does smbfs support reading large files like this?
  • »22.07.12 - 12:26
    Posts: 12559 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=8121&start=31
  • »22.07.12 - 19:34
    Posts: 1096 from 2004/9/23
    You need a fixed smbfs with full 64bit support, which exists, but is AFAIR not official released.
    Geit
  • »22.07.12 - 19:49
