SMBFS loses NAS on Powerbook only.
    matt3
    Posts: 784 from 2004/2/10
    This is the strangest issue.
    I have a PB with 3.0, it was working perfectly with my NAS via SMBFS.
    Now it won't connect with a 'unknown host' error.
    I thought the NAS had a problem so I tried connecting to it with my Peg II, no problem at all.
    I can connect to other windows shares on my PB via SMBFS. That's why this one is so strange.
    I can use same command on both boxes running MOS 3.0 and the same version of SMBFS. One connects and the other doesn't.
    After I try to connect to the NAS it trashes the internet on the PB and I have to reboot before I can get on the web.
    Any Ideas? A bug ???
  • »15.07.12 - 23:43
    Posts: 1090 from 2004/9/23
    You need to add the NAS with the correct name to hosts list in MorphOS preferences.
    SMBFS is quite stupid. Even if you access a device by IP it checks for a name in host list and if there is non, it fails.
    Geit
  • »16.07.12 - 10:29
