Iphone problem
    Divinity
    Posts: 498 from 2009/9/8
    I have a problem with Iphone 3G; connected via USB to MorphOS, no mount to see/copy the pictures inside
    Poseidon USB stack (MorphOS 3.1):
    Iphone class Multiple, bindings ptp.class
    23:02:12| 0-hub.class: Zapping device 'iPhone' at port 3!
    23:02:12| 0-poseidon.library: Device 'iPhone' says it is currently bus-powered. Fixing config.
    23:02:12| 0-hub.class: Device 'iPhone' returned. Happy happy joy joy.
    23:02:12| 0-ptp.class: Hold still for images from for 'iPhone'!
    23:02:12| 10-ptp.class: Command 'GetDeviceInfo' (1001) failed: response timeout (6)!
    23:02:12| 10-ptp.class: Command 'OpenSession' (1002) failed: response timeout (6)!
    23:02:12| 10-ptp.class: Command 'GetStorageIDs' (1004) failed: response timeout (6)!
    ideas to solve the problem ?
  • »15.07.12 - 19:06
    Posts: 1070 from 2004/9/23
    Try a hub inbetween.
    This fixes most timing issues. Ipad works here fine.
    Geit
  • »15.07.12 - 20:07
    Divinity
    Hi Guido :)
    I need to find a hub USB :)
  • »15.07.12 - 21:05
    xyphoid
    Posts: 870 from 2008/7/11
    Well while the thread is up.....so no GTkPod or rhythmbox port huh?
    Wouild be nice to have a music/media manager for a ipod.
    I noticed mine a bit more stable now, but all i get is the mounted device
    apple ipod, and selecting it gives internal storage folder, and then DCIM
    but I can't view anything. They appear empty. This is on the older ipod touch
    model without the camera. Ipod touch with camera mounts and i see pics in
    folder, but eventually self unmounts within 5mins or so.
    [ Edited by xyphoid 15.07.2012 - 18:31 ]
  • »15.07.12 - 21:08
