Various new user questions
    runequester
    Posts: 106 from 2010/1/11
    Some of these might be stupid questions
    Is there a way to remap the "three finger reboot" to different keys?
    When the adapter arrives, Id like to use an old IBM keyboard (with a PS2 to USB adapter), if that works out. But theres no widows keys on that.
    Any way to show available video RAM at the top of ambient, like old amiga OS did?
    A more application specific question: Any way to get jabberwocky to open URLs in OWB?
    Can I use a normal cheap PCI card to add some USB slots? Will MOS support USB 2 this way ?
    I think thats it for right now...
    Thank you in advance
    [ Edited by runequester 12.07.2012 - 18:00 ]
    Amiga 1200 and G4 MDD MOS as my main computers.
  • »12.07.12 - 15:53
    Posts: 2539 from 2003/2/24
    Video-RAM :
    - Right-click the screen-depth gadget
    - select modules->graphicsmemory
    Jabber:
    - there is a setting for this in Prefs->System->OpenURL (assuming Jabberwocky supports OpenURL)
    - if not there might a special setting in jabberwockie's settings.
    USB:
    - NEC-based cards are reported to be working best (and yes general PC cards)
  • »12.07.12 - 16:13
    redrumloa
    Posts: 1424 from 2003/4/13
    Kronos,
    USB:
    I have a no-name USB in my Quicksilver 2002 and it works flawlessly.
    runequester, just make sure it is a USB2 :-)
  • »12.07.12 - 16:17
    runequester
    Thanks guys. Any idea on the keyboard reboot ?
  • »12.07.12 - 16:39
    Simon
    Posts: 809 from 2008/7/6
    Every cheap Chinese USB2 card that is sold on Ebay as Powermac G4 / OSX compatible card will work in MorphOS.
    Not sure on the keyboard, I use a generic PC-USB keyboard and do CTRL-windows-windows to reset.
  • »13.07.12 - 08:28
    Korni
    Posts: 473 from 2006/2/23
    Hotkey to reboot command using mmkeyboard or poseidon. You can also emulate missing command keys.
    As for video ram like on AmigaOS, open screenbar MUI settings and go to Titlebar.
    [ Edited by Korni 13.07.2012 - 12:21 ]
  • »13.07.12 - 09:07
    Posts: 1368 from 2010/1/6
    AFAIK 3-key reset is not changeable without harware modification......but you can use the reset button instead - pins located on motherboard (think you have a Pegasos?)
    Btw.: Why don't you use an new keboard? It's really cheap.......
  • »13.07.12 - 09:09
    Korni
    New mechanical keyboards aren't really cheap.
  • »13.07.12 - 09:27
    @AmigaHarry2
    Surely no HW involved (why would Mac-HW know about a specific Amiga/MorphOS kex combo)
    Enabling a different KBD-reset might be possible from within Poseidon-config, problem this one wouldn't work when ABox has crashed.
    Changing/disabling the standard one would require access to Quark-sources (atleast thats what I would guess).
  • »13.07.12 - 09:43
    runequester
    Korni,
    no, a new "clicky" goes for 80 dollars or so. I got my IBM model M for 10 off ebay and its the best damn keyboard Ive ever used :)
  • »13.07.12 - 10:37
    Posts: 1075 from 2004/9/23
    Just a small note. I some application does not support OpenURL, but is able to launch some program, then you can use the "Open" command instead.
    It will use OpenURL on a link and beside that act like you double clicked the file itself. This allows you to use the Ambient/OpenURL setup even with non supporting tools.
    Geit
  • »13.07.12 - 12:14
    runequester
    Thanks! I'll poke around jabber and see if i can get it to play nice
  • »13.07.12 - 13:58
    runequester
    okay, so another question: I was quite pleased to see a version of Angband and Battle for Wesnoth available :)
    I also tried to install ADoom and Aleph One.
    For Adoom, is there a way to get it to open in a window, instead of a separate screen? (the doom window only fills part of the new screen, leaving the rest grey)
    Aleph One will run but it complains it's out of RAM, despite my system being nowhere out of memory. Any suggestions?
  • »13.07.12 - 15:21
    Posts: 1520 from 2003/2/24
    There is 3.06 version available at Aminet. Just few weeks ago I ported newer version and it is almost ready but I forgot it since then... must take a look at it again...
  • »13.07.12 - 16:52
    xyphoid
    Posts: 870 from 2008/7/11
    I remapped my right missing win logo key aka right amiga to right ctrl. there is a thread on the forum on this.
  • »13.07.12 - 17:13
    @Kronos:
    Oh, you missunderstood me.... I thought about a sort of adapter between Keyboard and USB which can translate the propper key-codes......not about a modification of mother-board - this makes no sense, indeed!
    I know that a modification of Quark-Kernel will also solve that, but I dont think MOS-Developers will do.......
    Btw.: I did'nt find a way to change reset-key-combination in Poseidons hid.class.....
  • »13.07.12 - 18:10
    runequester
    another question: I copied Final Writer over from my amiga, and it loads up fine. However, if I open on its own screen, it only takes up half the screen, with the rest being blank.
    It'll open in workbench (ambient of course, but Final Writer doesn't know that), but that makes the default colour a pretty uncomfortable grey that makes it hard to read. Anyone familiar with Final Writer in MOS, and have some tips on how to make it fit in a little better?
    edit: This might be stupid, but do I need to install something to have opengl/tinygl support, or is that included by default?
    [ Edited by runequester 13.07.2012 - 20:26 ]
  • »13.07.12 - 18:24
    Posts: 12498 from 2003/5/22
    The latter.
  • »13.07.12 - 18:35
    runequester
    most excellent :)
  • »13.07.12 - 18:55
    Posts: 2206 from 2003/2/24
    runequester,
    Hmmm.. I haven't had problems it filling the whole screen. Do you try to open it to some screen mode which doesn't exist in your system? Does that mode look good when you test it in Monitors settings in system prefs?
  • »14.07.12 - 06:36
    Choose "Ask at startup" in FW-Project-Preferences (startup). Restart FW. FW will ask you for a screen -> choose a propper screenmodi from list
    The best results with colours you will get only useing a 8Bit-Screen (i.g. 1680x1050x8), because FW can't handle more than 256 colours....
    If FW looks strange nevertheless, then play a bit with screen-colours ins FW-Project-Prefs/Screencolours.....
    If you cannot change Prefs in FW (maybe FW crashes or anything else), then rename FWFiles/FW.prefs to FWFiles/FW.prefs_old and start FW again. Prefs are "reset" now and the screen-requester should appear ......
    If you have found a propper screen, you can fix it in FW-Prefs, useing point "Open new screen" - so you need not choose it every startup....
    Btw. there is a small bug: To use buttons from tools-window , you have to activate window first by clicking to its border. It won't be activated by only clicking in its content.....
  • »14.07.12 - 09:22
    runequester
    thanks for the tips. I'll play around with that and see what I can get sorted out.
  • »14.07.12 - 10:38
    redrumloa
    runequester,
    Are you using an Apple Cinema Display? I gave up and went back to a 4:3 display. Life has been a lot easier.
    -Edit-
    Keep in mind at this point in my life I am not a tinkerer. That is why I like MorphOS over the alternatives. I turn it on, it works. I install something, generally it works.
    [ Edited by redrumloa 14.07.2012 - 08:06 ]
  • »14.07.12 - 11:01
    runequester
    Yeah the amount of "work" has been pretty low. Grunch helps too :)
    the biggest fuss was hunting down some MUI classes that Yam wanted.
    As far as monitor, its a dell 2320, shared with my 1200. (wonderful beast that monitor is)
  • »14.07.12 - 11:30
