MorphOSBoot CD 3.2+
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    @MorphOS Developer
    Plz copy this file icontrol.conf to new MorphOSBootCD/efikainstall.img > Prefs/Env-Archive/sys/
    icontrol.conf
    Flags=0x12C3C0
    End
    - included moving the windows beyond screen.
    [ Edited by SKOLMAN_MWS 12.07.2012 - 02:20 ]
    _
  • »11.07.12 - 23:14
    Jeckel
    Posts: 133 from 2007/3/11
    You just have to use the depth gadget to manage your windows without moving them all the time. This way, there is no real need to move windows out of the screen (which is according to me a bad practice).
  • »12.07.12 - 07:16
    Posts: 1090 from 2004/9/23
    You can also move the windows out of screen by holding the ctrl key down.
    I don“t see a problem in the current behaviour.
    Geit
  • »12.07.12 - 09:30
    Miky060
    Posts: 694 from 2003/2/24
    @SKOLMAN_MWS
    :-D You'll never convince them!!
    It's years that many users ask them to let windows moving outside the screen as default settings, but MorphOS developers do not like this way to operate so you'll never have this setting as default in the CD! Forget it, I did it ages ago..
  • »12.07.12 - 10:45
