Dualboot and PowerBook
    imax
    Posts: 41 from 2004/9/20
    Hi All!
    I install MOS2.6 and X 10.5.6 at macmini and load MOS set to default. I do upgrade to MOS 3.0 and no problem.
    With PowerBook 1,5G 15" i change :
    setenv boot-command boot hd:4,\\bootinfo.txt
    and i see gray screen.
    restore to mac-boot do load OSX default.
    What means ?
  • »19.06.12 - 15:16
    Posts: 3275 from 2003/3/5
    Quite likely the partition number needs to be adjusted. Try to type dir hd:4,\ and see if the bootinfo.txt file is there - if not, you need to adjust the number.
  • »19.06.12 - 15:56
    imax
    Hrrrr !
    Yes its partition named "Boot".
    I will load MOS3 at command :
    My be will be pause for waiting hdd ?
    [ Edited by imax 22.06.2012 - 22:09 ]
  • »22.06.12 - 17:08
    How do you set the env command exactly ?
  • »22.06.12 - 18:11
    Divinity
    Posts: 498 from 2009/9/8
    my opinion:
    use YABOOT; in these way you don't need to change the OpenFirware.
    If you need to change something, you'll edit only the yaboot config file
  • »22.06.12 - 18:34
    imax
    jacadcaps,
  • »23.06.12 - 02:17
    Miky060
    Posts: 694 from 2003/2/24
    I had similar problem..
    Did you type "shut-down" after that?
  • »23.06.12 - 05:48
    It should be just one backslash as far as I remember. Also, you need to issue a reset-all command to save your changes.
  • »23.06.12 - 12:45
    Miky060
    @jacadcaps
    In my case the "reset-all" command did not work on the powerbook (th new env variable was not stored!) while a "shut-down" worked! I don't know why.
  • »23.06.12 - 20:14
    MorphDelf
    Posts: 274 from 2004/2/20
    hi, you don't need to put hd:x if bootinfo.txt is in the first partition, like I have.
    So, for me if I want to boot, I type this:
    boot hd:,\boot.img
    If you want to save it, I type this:
    setenv boot-command boot hd:,\bootinfo.txt
    Hope this helps. Worked for me.
  • »23.06.12 - 21:01
    imax
    i may start MOS3.0 from OF both command:
    boot hd:4,\bootinfo.txt
    reset-all for save - of couse.
    printenv show all changed OK, but i see gray screen.
    Will be any command OF for wait ?
  • »25.06.12 - 16:45
