Posts: 2728 from 2003/2/24
WeiXing3D,
OK. Thnas to the help of some of the members in the forum, I am ready to take the plunge and join the MorphOS commmunity.
I have a Mac Mini G4 1.5 GHZ, with 80GB HDD and wireless card. Will this system config. work?
If yes, what do I do next? Where can I buy and download the software? Any other tips are welcome. Thanks in advance for any help given.
Congratulations to your Mini G4 1.5GHz. I have one of those as well, and the best thing about them is the 64MB VideoRam (if it is a "true" 1.5GHz and not an overclocked 1.42 machine). This is an excellent machine IMHO for MorphOS. Very small (not expandable though), very silent, and very powerful for a G4 system. I think the Mini is great!
It will work perfectly out of the box, with wired Interent. WiFi is not supported yet, maybe in the future.
Next step is downloading and trying the full MorphOS 3.0 software. This is free, but after running the OS for about 30 minutes, things will slow down to an unbearable level, unless you have registered and payed the fee of course. Then you receive a key file that unlocks that annoying demo limitation. Luckily for you, the price for Mini registrations was recently reduced to only 79, and registration gets tied to that particular hardware only, not you as a user. The keyfile gets hardcoded to the machine from which you send the registration request. Good to know. If you sell he computer, MorphOS registration follows with it, so make sure to charge money for that too!
Anyway, you download the OS it here:
http://morphos-team.net/downloads
Installations guides are here: http://morphos-team.net/installation
If you want to run MacOS and MorphOS on the same machine, and dual boot in between them, then you will have to take some special steps, how to do this can be found in this guide:
http://library.morph.zone/Dual-boot_MorphOS_and_MacOS_X_on_a_Mac_Mini_G4
Welcome BTW, and Good luck, and welcome back if you have any questions!
MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
