How do I set upp UAE in MorphOS?
    metalmac
    Posts: 87 from 2007/5/26
    Hi!
    Anyone that nows a guide how to set up a classic sesion under MorphOS.
    I would like to have one config with Workbench and one 500 and one 1200 emulator.
    Is that posible, I want to play classic games :-)
    I have tryed UAE4All and it seems to work, but I cant get it to full screen, the screen is only in the upper left corner, is there a way to get it full screen?
    [ Edited by metalmac 12.06.2012 - 19:45 ]
    PowerBook G4@1.5Ghz, 1Gb ram, MorphOS 3.12
    Amiga 1200, Blizzard 1220/4@28Mhz, 500Mb HD, 6mb RAM, Workbench 3.1
    AspireOne, 1Gb RAM, 160Gb HD, Icaros Desktop
    AmigaOne 500, 2Gb ram, AmigaOS 4.1 Final Edition
  • »12.06.12 - 17:41
    Posts: 12570 from 2003/5/22
    The ones linked there are said to be helpful:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=10&topic_id=6264&start=40
  • »12.06.12 - 17:52
    Simon
    Posts: 809 from 2008/7/6
    searching the forums for UAE should get you there ... i kind of forgot how to configure it
  • »12.06.12 - 17:54
    metalmac
    I have installed E-UAE, but I just cant figure out how to use uaerc files?
    Someone that has the nowlage should make amiga emulation user friendley on MorphOS.
    I meen, it should be built in to the system as standard, it is easyer to emulate on windows.
  • »13.06.12 - 19:14
    Simon
    You could install the pack ultimate ... I think UAE is configured then. But the roms you have to get elsewhere since they can't be added without Ainc knocking on the door.
  • »13.06.12 - 19:20
    XzIt
    Posts: 250 from 2005/1/19
    Check this out
    http://aminet.net/package/misc/emu/rhLaunch-morphos
    X
    [ Edited by XzIt 13.06.2012 - 23:14 ]
  • »13.06.12 - 20:11
    metalmac
    Thanks, I tryed rhlaunch, but I cant do anything with it, I must say that the classic emulation is realy a pain in the ass for someone like me ho is just a user.
    Someone should make a installer that installs everything, the only thing I as a user should do is bringing the kickstart files and the wb3.1 adf and off we go.
    I tryed follow the guide on meta-morphos to, but I just cant get it to work, how do I use a .uaerc file for example? Do I have to use the shell or somthing and putt in comands and stuff?
    Ooo well, maby it is best for me to just use AmigaForever on my PC, but that wouldent be so Amiga as this would be :-(
  • »14.06.12 - 04:27
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Well, it's not complicated. I even provided presets for A1200, A500 and Workbench usage in the archive, in Conf/ directory.
    Assuming you put the kickstart files in the right place (roms/ directory), you just start UAE that way:
    uae -f conf/A500.conf or
    uae -f conf/A1200.conf or
    uae -f conf/wb.conf
    and so on ...
    if you need to pass an adf, you do it that way:
    uae -f conf/A1200.conf -0 blah.adf
    Now, i suggest you bind UAE to ADF mimetype in Ambient with that kind of commaand : path:to/uae/uae -f path:to/uae/conf/blah.conf -0 %sp to ADF
    That way, you can start any ADF just by doubleclicking it.
    [ Edited by Fab 14.06.2012 - 08:33 ]
  • »14.06.12 - 06:31
    metalmac
    @Fab
    Thanks for the answer :-)
    I will try this out when I come home from my wakation.
    Sorry for sounding so negative, it is probably not so hard to set up
    wen Im not so stresed. :-)
  • »16.06.12 - 10:45
