MorphOS Files.net
    djrikki
    Posts: 16 from 2012/3/18
    Hello,
    Its been well over a week since I submitted Jack to MorphOS Files, who is charge of that place and what's the hold up?
  • »12.05.12 - 10:00
    pampers
    Posts: 1068 from 2009/2/26
    Krashan is in charge. I told him about your problem, he will take a look later on.
    MorphOS 3.x
  • »12.05.12 - 11:45
    Krashan
    Posts: 1107 from 2003/6/11
    1. I do not work on morphos-files.net 24 hours and 7 days a week.
    2. The URL you have specified as the download link in the submit form gives me 404 error.
    3. When I try to download from the home page, I see some registration form, which is said to be disabled and advices for visiting OS4Depot.
    Then I simply don't know where I'm supposed to get the archive from.
    UPDATE
    Ok, you've simply mixed letter case in dowload path, downloaded it now.
    [ Edited by Krashan 12.05.2012 - 17:25 ]
  • »12.05.12 - 17:17
    Does Jack work on MorphOS2.7 now?
    I would like to see what Jack looks like on MorphOS2.7.
  • »12.05.12 - 17:26
    djrikki
    @krashan
    I understand, just that it had been over 10 days so I thought it wise to bring it up.
    @amigadave
    Correct. lol me too... I don't have any MorphOS hardware to check it on, but it has been confirmed as working.
    [ Edited by djrikki 13.05.2012 - 03:21 ]
  • »13.05.12 - 03:20
    Krashan
    @amigadave
    It still has some issues. I've sent a bugreport to the author. Of course non-working programs cannot be added to MorphOS Files.
  • »13.05.12 - 04:40
    Brumiga
    Posts: 275 from 2004/4/3
    @djrikki,
    Once I wanted to give your program a try but I have not been able to install it fully. Your install script did just copy a hollywood directory in libs: and create an empty directory in envarc:, and that were all. And about your install script, multiview path is 'sys:utilities/multiview', the same as on amigaos 3.x, 4.x, and/or maybe also on aros.
    Brumiga
  • »13.05.12 - 08:33
    Jambalah
    Posts: 820 from 2008/3/30
    @Amigadave & Djrikky:
    it looks like this:
    Jack on MorphOS
    Well, as noticed installation script doesn't work well on MorphOS. It creates only a Jack directory in envarc and the Hollywood directory in Libs.
    Manually it's possible to do some more:
    the first step is to create a directory named "Jack" in the place you like on your hard disk.
    Inside this directroy copy the executable of program (using the MorphOS version of course).
    Copy every file inside "Distribution/Jack" directory inside your "Jack" dir and then the whole "OBjs" directory in the same place.
    The Python libs should be copied inside "SYS:Libs/Python", copying the whole "Mutagen" directory and "itv.py", "jack_getmpeginfo.py", "mid3v2"and "mutagen-inspect" files.
    Copy "WebP" datatype in "Sys:Classes/Datatypes".
    Copy Hollywood libs in "Sys/Libs" and create a directory named "Jack" in "Sys:Prefs/Env-Archive" (this two operations could be ignored if you have just started Jack installation script, since it perform those operation by itself)
    OpenURL directoy and its preference program could be ignored as MorphOS has those programs implemented yet.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »14.05.12 - 08:22
