help i'm melting
    digitaldust
    Posts: 4 from 2012/5/10
    Hello is there a step by step install guide ?
    also when i am installing my morphos it stops coping files with the install option ghosted out and the DH1 System vol can be clicked on , the install will un ghost and i click it looks like its coping more files then is stops for ever. then i click on the DH1 again there is a different number of files copied . should it be showing me something in the tall window that has the Drive list on the top and the install button on the bottom ?
    thanks for any help i tried to get access to the wiki but i can not make a account ?
    thanks again I'm also on the form as digitaldust
  • »10.05.12 - 19:45
    Posts: 12570 from 2003/5/22
    https://morph.zone/news/1920.html
  • »10.05.12 - 19:59
    digitaldust
    Ok well that is good as a whole i have to say , Might i have a bad install disc or hardrive as the install wizard does this stop and wait till i click on the drive then hit install over and over ?
    It really seems once morphos times out is when the file copy really gets to work installing the os ?
    and are there no install instructions ??
  • »11.05.12 - 01:44
    digitaldust
    BAD CAPS ! i spent about 2hrs installing hard-drives , cdroms , to look down and see a bad cap ! now i'm chilling again she is fixed up and on the move with a nice install and everything seems to be working .
    So if a Mac PPC G4 500Mhz is doing the I dont like to keep installingwith out having to have a person click the mouse on the window '' look for bad caps !
  • »11.05.12 - 02:16
