Preinstall MUI38 68k allowed?
    OlafSch
    Posts: 191 from 2011/11/16
    Hello,
    short question. MUI was commercial so I want to ask if I am allowed to preinstall MUI38 68k (unregistered version from Aminet) in a Aros 68k distribution I am working on.
    Am I allowed to?
  • »16.01.12 - 09:17
    Posts: 12539 from 2003/5/22
    > Am I allowed to?
    I think Stefan Stuntz is not a member here, so you better contact him by other means.
  • »16.01.12 - 09:36
    Posts: 2730 from 2003/2/24
    MUI was commercial
    Wasn't it shareware where the deal was you could freely use a somewhat limited version (on the Aminet) for free, but if you supported the developer by purchasing a key file, you had a lock unlocked resulting in much better possibilities of customizing its appearance?
  • »16.01.12 - 10:16
    stephen_robinson
    Posts: 746 from 2007/4/22
    Dosn't Amikit have it?
  • »16.01.12 - 15:34
    From the "License" part of the MUI.guide file:
    - This license applies to the product called "MagicUserInterface"
    (short "MUI"), a collection of programs for the Amiga computer,
    published by Stefan Stuntz under the concepts of shareware, and
    the accompanying documentation. The terms "Program" and "MUI"
    below, refer to this product. The licensee is addressed as "you".
    - You may copy and distribute verbatim copies of the program's
    executable code and documentation as you receive it, in any
    medium, provided that you conspicuously and appropriately publish
    only the original, unmodified program, with all copyright notices
    and disclaimers of warranty intact and including all the
    accompanying documentation, example files and anything else that
    came with the original.
    - Except when otherwise stated in this documentation, you may not
    copy and/or distribute this program without the accompanying
    documentation and other additional files that came with the
    original. You may not copy and/or distribute modified versions of
    this program.
    - You may not copy, modify, sublicense, distribute or transfer the
    program except as expressly provided under this license. Any
    attempt otherwise to copy, modify, sublicense, distribute or
    transfer the program is void, and will automatically terminate
    your rights to use the program under this license. However,
    parties who have received copies, or rights to use copies, from
    you under this license will not have their licenses terminated so
    long as such parties remain in full compliance.
    - By copying, distributing and/or using the program you indicate your
    acceptance of this license to do so, and all its terms and
    conditions.
    - Each time you redistribute the program, the recipient automatically
    receives a license from the original licensor to copy, distribute
    and/or use the program subject to these terms and conditions.
    You
    may not impose any further restrictions on the recipients'
    exercise of the rights granted herein.
    - You may not disassemble, decompile, re-source or otherwise reverse
    engineer the program.
    - You agree to cease distributing the program and data involved if
    requested to do so by the author.
    Seems that there should be no problems, as long as:
    1) You distribute the whole package, meaning every single file in the original archive, including all the documentation and example files
    2) You don't distribute modified versions
    3) You don't try to disassemble or re-engineer it in any way
    So leave the package contents untouched and I guess it should be fine, and the users of your AROS 68k distro is automatically granted their own license to use the MUI you have distributed to them.
    But if you "upgrade it", developing it further, reverse engineer it, or change it in any other way, then you have breached the MUI license.
    Right?
  • »16.01.12 - 18:09
    OlafSch
    thank you for the information
  • »17.01.12 - 10:35
