720p on Powerbook 9139?
    matt3
    Posts: 785 from 2004/2/10
    Mixed results in playing 720p video on OS X and my PB.
    It doesn't play files in 720p smoothly. I have used VLC, Quicktime, XMBC. I turned the performance all the way up for when it is plugged in. It generates alot of heat and doesn't play back smoothly. The PB even has a SSD in it.
    Any ideas?
    Does Morphos 3.0 do a better job with this?
  • »10.01.12 - 09:29
    SoundSquare
    Posts: 1214 from 2004/12/1
    yes, like it was shown many times (on mac mini for example).
  • »10.01.12 - 09:45
    Posts: 12552 from 2003/5/22
    Maybe wrong program? :-)
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=7579&start=75
  • »10.01.12 - 22:38
