Best system for MOS 3.x ?
    jalla
    Posts: 57 from 2004/10/4
    Time to change my hardware.
    I guess this has been stated several times earlier but I'm not sure how updated the posts on the forums are compared to features and support of recent os-versions. Could anyone give me a spesific spec/model name of the best MorphOS 3.x hardware available out there ? A bit scared to get into ebay to buy something that wont even boot. I understand there are many variations on each Mac model and I'm really not familiar with theese machines. A laptop would definatly be the coolest.
    Sound-, net- and 3D-drivers must be available for my preferred system.
    Have a Peg2 1GHz +Radeon9200 +512MB at the moment and I like it very much but I feel the speed lacks a bit sometimes.
    Btw: are there any special price for the second MOS lisence ?
    Pegasos II/G4/512MB/Radeon9200
  • »21.12.11 - 20:06
    pan1k
    Posts: 147 from 2009/1/20
    I suppose you could get a MacMini with a higher CPU clockspeed. I just upgraded my PegII to a Radeon 9100, and 1gb of ram. Seems to work just fine..
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »21.12.11 - 20:20
    Miky060
    Posts: 694 from 2003/2/24
    - If you buy a MacMini absolutely find a 1,5Ghz one (with 64MB of videoram)
    - If you want a Powerbook look for a 5,8 (15") or 5,9 (17") one. They both have G4@1,67Ghz, DDR2 Ram and Radeon 9700 with 128mb of videoram.
    - If you want a PowerMac the best choice is an MDD one (Mirrored Drive Doors), and they should be the fastest MorphOS machine at the moment. I would buy a single 1,25Ghz one (the best one to be overclocked) or a dual 1,42Ghz. These CPUs are the 7455 with 1/2MB of L3 cache so faster (even if with lower frequency..) than the CPUs you find on the Mini/PowerBook/Pegasos. Don't buy a Quicksilver, they are good enough machine but not the fastest choice as you ask.
    The fastest gfx board fully (2D+3D) supported by Morphos in this moment is the Radeon 8500. Maybe in next months even 9700/9800 will have 3D support.
    Give a look at MDD 1,25Ghz specs..
    http://www.everymac.com/systems/apple/powermac_g4/stats/powermac_g4_1.25_mdd.html
    [ Edited by Miky060 21.12.2011 - 22:38 ]
  • »21.12.11 - 20:32
    jalla
    Yes I guess a Mac Mini will do it for me :).
    Are they standarized with some MOS supported gfx card and sound card or do thay have something builtin?
  • »21.12.11 - 20:49
    Miky060
    They all have Radeon 9200 (the slowest Radeon of the history..) but only the 1,5Ghz one has 64MB of Ram (the 1,25/1,33/1,42Ghz Mini have 32MB of videoram), so buy a 1,5Ghz version! They are not always easy to find..
    http://www.everymac.com/systems/apple/mac_mini/index-macmini.html
    A MacMini is a nice toy, I have one, but a MDD is much easier to open and upgrade..
    [ Edited by Miky060 21.12.2011 - 23:10 ]
  • »21.12.11 - 21:07
    matt3
    Posts: 785 from 2004/2/10
    If you think a laptop would be cool, go for the PB 1139. It should be faster than the mini.
    Right, kinda crazy to be a unsupported system for and os that doesn't exist yet... Bought mine a few days ago...  :-?
    OS X sucks, running the latest version of OS X for PPC and apps locks up with the wheel of death that won't force quit, and even crashed the kernel running VLC player. What a big disappointment, can't wait until 3.0 is released...
  • »21.12.11 - 21:23
    Posts: 12570 from 2003/5/22
    > hardware available out there ? [...] I'm really not familiar with theese machines.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8036&forum=11
    Unfortunately, 3D drivers for PowerBooks' Radeon 9700 are announced to come only after MorphOS 3.0.
  • »21.12.11 - 22:01
    > Are they standarized with some MOS supported [...] sound card or do
    Sound is built-in with the Mac mini and supported by MorphOS of course.
  • »21.12.11 - 22:10
    I think that Radeons 7000, 7200 and 7500 are slower than any version of Radeon 9200.
  • »21.12.11 - 22:17
    I was going to respond to that but Andreas beat me to it.
    And some Radeon IGPs are even slower (but since they're not supported by MorphOS that's not important).
  • »22.12.11 - 12:29
    Miky060
    Andreas_Wolf,
    Yes, I would have written the 9200 is ONE OF THE slowest Radeons of the history. I totally forgot about 7x00 series because they are so old that I would not consider them. In every case the "7xxx" let you understand that it's a low level gfx board while the "9200" code is misleading letting you believe it's faster than 9100/9000/8500, for this reason I will never end to advise people that the 9200 is a very slow board!
    The order (from the fastest fully supported by MorphOS 2.7 to the slowest) should be 8500>=9100>9000/Pro>9250/9200>7500>...
    Remember that 9100 is a relabeled 8500, but in most cases it has little slower Clock/Mem speed so the 8500 remains the fastest 2D/3D gfx currently supported by MorphOS.
    When 9500/9600/9700/9800 will finally have 3D support there will be a huge gain in performance..
  • »23.12.11 - 06:51
    Miky060
    This is a bargain (64MB of videoRam, 1GB of Ram already installed, Airport and Bluetooth, 80 GB HD..), ask to amigadave to let you have one:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8238&forum=38
  • »23.12.11 - 07:00
    Everblue
    Posts: 170 from 2004/1/6
    Jalla, you got a private message :)
  • »23.12.11 - 08:37
    That's because the 9100 is actually a relabeled 8500LE.
  • »23.12.11 - 09:03
